If the field is in the active temporary table/dataset you would use the
following line..
Assign ttLaborDtl.BurdenRate = 0. (as an example)
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of Don Kollmann
Sent: Friday, October 01, 2010 4:32 PM
Subject: RE: [Vantage] BPM from EndActivity MES 409A
Thank You Rob
How would you intercept and update a field at this time?
Don
Behalf Of Rob Bucek
Sent: Friday, October 01, 2010 3:34 PM
Labor.update
Used a preprocess
Action execute 4gl code
for each ttlabordtl where ttlabordtl.rowmod = 'U' and
ttlabordtl.LaborType = 'i' no-lock.
{lib/PublishInfoMsg.i &InfoMsg = "'Indirect Labor'"}.
End.
Down and dirty but it will demonstrate functionality..
Rob Bucek
FAX: (715)284-4084
<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>]
On Behalf
Of Don Kollmann
Sent: Friday, October 01, 2010 3:12 PM
Subject: [Vantage] BPM from EndActivity MES 409A
Hi Group,
What business process is called when the OK button is selected at
EndActivity in the MES
I am trying to throw an informational message based on Labor Type and
have not had any luck.
The trace appears to be labor and update but I have not gotten any
results
Thank you
Don Kollmann
ERP / IS Support
[cid:926080920@01102010-1D63]
Phone: 920-924-4050 Ext 325 / 800-236-5377
Fax: 920-924-4042
following line..
Rob Bucek
FAX: (715)284-4084
Of Don Kollmann
Thank You Rob
Don
Behalf Of Rob Bucek
Labor.update
Used a preprocess
End.
Rob Bucek
FAX: (715)284-4084
On Behalf
Of Don Kollmann
Hi Group,
results
Thank you
Don Kollmann
ERP / IS Support
Fax: 920-924-4042
