BPM in 9.05.700C
The only “action” was a pop up message.  Manasa
Sent: Thursday, November 13, 2014 12:04 PM
Subject: Re: [Vantage] RE: BPM in 9.05.700C
I feel like there is some info missing.  Was there more for Action?  Is there a condition?
On Wednesday, November 12, 2014 7:07 AM, "Manasa Reddy mreddy@... [vantage]" <vantage@yahoogroups.com> wrote:
Thanks, Steve!  Manasa
Sent: Tuesday, November 11, 2014 4:05 PM
Subject: [Vantage] RE: BPM in 9.05.700C
The RowMod is an external column that represents the state of the row.
So in basic terms you have “A” = Added, “D” = Deleted, “U” = Updated and “” = Unmodified.
You don’t however need the first two clauses like you have below that is being done by the system when you use that condition.
Sent: 11 November 2014 22:00
Subject: [Vantage] BPM in 9.05.700C
My predecessor created a BPM in Job Entry which when I read it makes absolutely no sense to me.  I thought I would share it with all of you and see if it makes sense to anyone.
(the JobHead.RowMod field of the changed row is equal to the "A" expression
or the JobHead.RowMod field of the changed row is equal to the "U" expression)
and the JobHead.JobReleased field of the changed row is equal to the True expression
All I want to know is what the “A” and “U” mean.  Can anyone shed any light on this for me?
TIA, Manasa
Stephen Edginton (Beng) | Solutions & Technical Director
Mobile:
 +44 7734 858415
DDI:
 +44 121 314 1179
Main:
 +44 (0) 121 314 1170
Web:
Dot Net IT Limited, One St Kenelm Court, Steel Park Road, Halesowen, B62 8HD, United Kingdom.
TIA, Manasa
#ygrps-yiv-1511056904 P.ygrps-yiv-1511056904d308bcc0-9c18-4ece-87ae-614b71f65790 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1511056904 LI.ygrps-yiv-1511056904d308bcc0-9c18-4ece-87ae-614b71f65790 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1511056904 DIV.ygrps-yiv-1511056904d308bcc0-9c18-4ece-87ae-614b71f65790 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1511056904 TABLE.ygrps-yiv-1511056904d308bcc0-9c18-4ece-87ae-614b71f65790Table { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1511056904 DIV.ygrps-yiv-1511056904Section1 { }
TIA, Manasa
Mobile:  +44 7734 858415
DDI:  +44 121 314 1179
Main:  +44 (0) 121 314 1170
Web:  www.dotnetit.co.uk
DotNetIT
Epicor Platinum Partner
Epicor Alliance Partner
TIA, Manasa
Mobile:
 +44 7734 858415
DDI:
 +44 121 314 1179
Main:
Web:
 www.dotnetit.co.uk
DotNetIT
<div id="ygrps-yiv-1126656359yiv0897392472ygrp-text">
  <div>
TIA, Manasa
Mobile:
 +44 7734 858415
DDI:
 +44 121 314 1179
Main:
Web:
DotNetIT
</div>
<div style="height:0px;color:rgb(255, 255, 255);"></div></div>
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472 -- #ygrps-yiv-1126656359yiv0897392472ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-mkp #ygrps-yiv-1126656359yiv0897392472hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-mkp #ygrps-yiv-1126656359yiv0897392472ads {
margin-bottom:10px;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-mkp .ygrps-yiv-1126656359yiv0897392472ad {
padding:0 0;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-mkp .ygrps-yiv-1126656359yiv0897392472ad p {
margin:0;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-mkp .ygrps-yiv-1126656359yiv0897392472ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-sponsor #ygrps-yiv-1126656359yiv0897392472ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-sponsor #ygrps-yiv-1126656359yiv0897392472ygrp-lc #ygrps-yiv-1126656359yiv0897392472hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-sponsor #ygrps-yiv-1126656359yiv0897392472ygrp-lc .ygrps-yiv-1126656359yiv0897392472ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472activity span {
font-weight:700;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472activity span span {
color:#ff7900;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472activity span .ygrps-yiv-1126656359yiv0897392472underline {
text-decoration:underline;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 .ygrps-yiv-1126656359yiv0897392472attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 .ygrps-yiv-1126656359yiv0897392472attach div a {
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 .ygrps-yiv-1126656359yiv0897392472attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 .ygrps-yiv-1126656359yiv0897392472attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 .ygrps-yiv-1126656359yiv0897392472attach label a {
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 .ygrps-yiv-1126656359yiv0897392472bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 .ygrps-yiv-1126656359yiv0897392472bold a {
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 dd.ygrps-yiv-1126656359yiv0897392472last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 dd.ygrps-yiv-1126656359yiv0897392472last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 dd.ygrps-yiv-1126656359yiv0897392472last p span.ygrps-yiv-1126656359yiv0897392472yshortcuts {
margin-right:0;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 div.ygrps-yiv-1126656359yiv0897392472attach-table div div a {
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 div.ygrps-yiv-1126656359yiv0897392472attach-table {
width:400px;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 div.ygrps-yiv-1126656359yiv0897392472file-title a, #ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 div.ygrps-yiv-1126656359yiv0897392472file-title a:active, #ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 div.ygrps-yiv-1126656359yiv0897392472file-title a:hover, #ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 div.ygrps-yiv-1126656359yiv0897392472file-title a:visited {
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 div.ygrps-yiv-1126656359yiv0897392472photo-title a, #ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 div.ygrps-yiv-1126656359yiv0897392472photo-title a:active, #ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 div.ygrps-yiv-1126656359yiv0897392472photo-title a:hover, #ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 div.ygrps-yiv-1126656359yiv0897392472photo-title a:visited {
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 div#ygrps-yiv-1126656359yiv0897392472ygrp-mlmsg #ygrps-yiv-1126656359yiv0897392472ygrp-msg p a span.ygrps-yiv-1126656359yiv0897392472yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 .ygrps-yiv-1126656359yiv0897392472green {
color:#628c2a;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 .ygrps-yiv-1126656359yiv0897392472MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 o {
font-size:0;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472photos div {
float:left;width:72px;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472reco-category {
font-size:77%;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472reco-desc {
font-size:77%;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 .ygrps-yiv-1126656359yiv0897392472replbq {
margin:4px;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-mlmsg select, #ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 input, #ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-mlmsg pre, #ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 code {
font:115% monospace;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-mlmsg #ygrps-yiv-1126656359yiv0897392472logo {
padding-bottom:10px;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-msg p#ygrps-yiv-1126656359yiv0897392472attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-reco #ygrps-yiv-1126656359yiv0897392472reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-sponsor #ygrps-yiv-1126656359yiv0897392472ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-sponsor #ygrps-yiv-1126656359yiv0897392472ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-sponsor #ygrps-yiv-1126656359yiv0897392472ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1126656359 #ygrps-yiv-1126656359yiv0897392472 #ygrps-yiv-1126656359yiv0897392472ygrp-vital ul li:last-child {
border-right:none !important;}
