Sorry, I am not reading the Vantage messages as timely these days...
From memory...You set up the BAQ export process - fill in filename as
????.csv for example, and save as a process set...I think you go into
Process Set, create a new one and add this BAQ export to it somehow...
Of Blake Clemens
Sent: Tuesday, August 10, 2010 1:51 PM
Subject: RE: [Vantage] BPM is it possible?
Could you give me some brief instructions on the correct way to set this
up?
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
Behalf
Of Karen Schoenung
Sent: Tuesday, August 10, 2010 12:08 PM
Yes, at least on 8.03.407b - try it and see...
Behalf
Of Blake Clemens
Sent: Tuesday, August 10, 2010 11:02 AM
So if I create a user named "test" and logged in as him and set up the
Process Set and saved it... then logged in as user "Phil" and ran the
Process Set the exported results would go to Test's folder and not
Phil's folder?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Karen Schoenung
Sent: Tuesday, August 10, 2010 11:58 AM
When I set this up here, the process set saved it to one username - the
user who was logged in when I did the setup. If you can share that
folder, maybe that will work?
Behalf
Of Blake Clemens
Sent: Tuesday, August 10, 2010 8:55 AM
Can I program where the file would get exported or would it have to be
the default?... servername\epicor\mfgsysdata\reports\username
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Karen Schoenung
Sent: Monday, August 09, 2010 5:36 PM
You can save the export process as part of a Process Set - for the user
to run when they want.
Behalf
Of Blake Clemens
Sent: Wednesday, August 04, 2010 3:25 PM
Yep. I've already done that. I want to control when the Query is
exported and where it is exported. I can do that now with the Query
Export Process and I can set it to a schedule so it runs every couple of
minutes but I want this to be something that a user can run without
using the Query Export Process and when ever they would need to run it.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Dines, Tim
Sent: Wednesday, August 04, 2010 4:20 PM
You can use a query to right the data you want to a file and save that
to a network location. From there, you can do anything you want with
the data, such as, a Crystal Report.
Tim Dines
ERP Analyst
Steel Parts Manufacturing, Inc.
801 Berryman Pike
Tipton, IN 46072
765-675-5201
Behalf
Of Blake Clemens
Sent: Wednesday, August 04, 2010 3:54 PM
Subject: [Vantage] BPM is it possible?
I want to add a check box to a menu. Then run a BPM when checked. I
want that BPM to export a BAQ to a specified folder on our network. Is
this possible? I'm not what is possible and what isn't when dealing
with BPMs.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of Blake Clemens
up?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Karen Schoenung
Behalf
Of Blake Clemens
Phil's folder?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Karen Schoenung
Behalf
Of Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Karen Schoenung
Behalf
Of Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Dines, Tim
Tim Dines
ERP Analyst
801 Berryman Pike
Tipton, IN 46072
765-675-5201
Behalf
Of Blake Clemens
with BPMs.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
