Thank you those sites helped. I was able to use your code to link the releases to the PO header when it is approved, but now I am trying to get the BPM to assess the G/L account to make sure it is valid when the Approval button is pushed. I set two conditions, the first being the one referenced before, the second referencing the G/L account fields. The second query looks like this:
for each GLAcctDisp, first TranGLC where GLAcctDisp.Company = TranGLC.Company and TranGLC.GLAccount = GLAcctDisp.GLAcctDisp no-lock
The condition I am using is 'number of rows in the specified query is less than 1'. Within the query, the TranGLC.GLAccount will accept invalid G/L numbers (this is also the field that is present in the maintenance form). The GLAcctDisp.GLAcctDisp field only accepts valid G/L Accounts.
When I run this BPM by executing the approval button in PO Entry Maintenance, the form seems to run in a loop, never finishing the 'approval' action. Once I end the process I get an error message that reads "Tried to call a method in an invalid procedure". I'm not sure what I am referencing in the second condition that is creating this error. Thanks for the help.
Eliza
Eliza
--- In vantage@yahoogroups.com, "McMullen, Travis" <tmcmullen@...> wrote:
> The query syntax is 4GL or ABL code which is a Progress language. Examples
> can be found in the Tools User guide if you have it, or you can go to the
> Progress website. A Google search of ABL or 4GL code should give a
> reference guide as one of the first 2 sites returned.
> As for the field not existing, that can be obtained by clicking in the
> field in PO Entry and going to Help > Field Level Help. This will give you
> the name of the field that you need to reference in the query.
> Travis L. McMullen
> ERP Specialist
> ComSonics, Inc.
> Harrisonburg, VA 22801
> Phone: 540-434-5965 x1274
> Toll Free: 1-800-336-9681 x1274
> Mobile: 540-435-1920
> Fax: 540-434-9847
> E-Mail: tmcmullen@...
> On Fri, Jun 8, 2012 at 4:27 PM, elizaroberts14 <
> eroberts@...> wrote:
> > I don't have the porel.expchart option, how does this affect the BPM? I am
> > using E905.607A. Where do you find information about query syntax through
> > Epicor? I am unable to find this information anywhere. Thanks for the
> > response.
> > --- In vantage@yahoogroups.com, "McMullen, Travis" <tmcmullen@> wrote:
> > > What version of Vantage/Epicor are you working with? If it's Vantage 8,
> > > you can't reference to different tables in separate conditions, even if
> > > they are in the same dataset. I had to do the following:
> > > I used the PO.ChangeApproveSwitch business method. I then created a
> > > Post-Processing directive. I used the 'number of rows in designed query
> > is
> > > not less than 1' condition. My query looks like this:
> > > for each ttPOHeader where (ttPOHeader.ApprovalStatus = 'A' or
> > > ttPOHeader.ApprovalStatus = 'P') , first PORel where PORel.Company =
> > > ttPOHeader.Company and PORel.PONum = ttPOHeader.PONum and PORel.ExpChart
> > > '999999' no-lock
> > > My users only wanted an informational message as the action, but you can
> > > also raise an exception.
> > > Travis L. McMullen
> > > ERP Specialist
> > > ComSonics, Inc.
> > > Fax: 540-434-9847
> > > E-Mail: tmcmullen@
> > > On Fri, Jun 8, 2012 at 3:37 PM, elizaroberts14 <
> > > eroberts@> wrote:
> > > > I am working on a BPM right now for PO Entry maintenance that ensures
> > that
> > > > the user has entered a G/L account at the release level before the PO
> > > > itself can be approved. When I input conditions involving header level
> > > > fields, for example POHeader.Approved = Yes, withan action statement
> > that
> > > > returns an error message, the BPM works correctly. However, when I
> > input
> > > > conditions that involve release level tables for the PO, ie
> > > > PORelTGLC.GLAccount or PORel.TranType, which is what I need for this
> > BPM to
> > > > work properly, the BPM no longer executes when I test it in the PO
> > Entry
> > > > Form. Does anyone know why this is, and if so, how to resolve the
> > issue?
> > > > I'm not sure why release level tables would not work in condition
> > > > statements, but header level fields do.
> > > > Thank you.
