Hi,
i wrote a DD on BPDirective Table, intention was to enter some logs once anybody updates any BPM, it was just a start, but there was some errors and got saved.
now i cannot update any BPM including the above, i cannot update/delete the same.
i tried to disable the BPM from DB directly, still the BPM is working and throws error, then i deleted, still the BPM is working and trows the error. then i deleted the BPM files from C:\inetpub\wwwroot\Epicor_Test2\Server\BPM\Sources\DT\ERP.BpDirective.Triggers
still the BPM is working and throws the error. where all other tables or files i have update/delete to get rid of this BPM.
created a BPM with same name on another test environment and tried to install using solution workbench installation failed with same error.
the below is the error
Server Side Exception
BPM runtime caught an unexpected exception of ‘FaultException’ type.
See more info in the Inner Exception section of Exception Details.
Error Detail
Description: BPM runtime caught an unexpected exception of ‘FaultException’ type.
Program: Epicor.System.dll
Method: ResolveService
Line Number: 94
Column Number: 17
Original Exception Type: FaultException
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets) at Ice.Proxy.BO.BpMethodImpl.Update(BpMethodDataSet ds) at Ice.Adapters.BpMethodAdapter.OnUpdate() at Ice.Lib.Framework.EpiBaseAdapter.Update() at Ice.UI.App.BpTriggerEntry.Transactions.MainTransaction.adapterUpdate() at Ice.Lib.Framework.EpiMultiViewTransaction.Update(IEnumerable1 dataSets)
Inner Exception
Type ‘Ice.Tables.UD11’ is not a service contract
