In pre-processing you should be able to set ttCallContextBpmData.Character01 to the employeeID. Then use ttCallContextBpmData.Character01 in place of employeeid
Sent: Thursday, July 11, 2013 3:13 PM
Subject: RE: [Vantage] BPM on Clock in / Clock out
Thanks, That's not what I wanted to hear, but I kind of figured out.
Calvin Dekker
Sent: Thursday, July 11, 2013 3:12 PM
Â
Yes. The post process directive would not have an Employee value.
Calvin Dekker
[cid:image001.jpg@01CE7E40.9D6E2090
<mailto:image001.jpg%4001CE7E40.9D6E2090> ]<http://www.codabears.com/>
630-672-7688 x1484
*Solutions for Epicor users.
"No trees were harmed during the sending of this message, however a large
number of electrons were terribly inconvenienced."
Behalf Of Mike Numbers
Sent: Thursday, July 11, 2013 1:54 PM
You and this users group are valuable selling features for Epicor.
One last? Question on this topic. I have my BPM working for the clockin
using a preprocessing method. On the clockout my testing shows the
parameter will work on a preprocessing method, but I need it for a post
processing method. It appears as if the parameter cleared before the post
processing method occurs. Does this sound right?
<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>] On
Behalf Of
Jose Gomez
Sent: Thursday, July 11, 2013 1:49 PM
To: Vantage
Subject: Re: [Vantage] BPM on Clock in / Clock out
haha if I was on Epicors payroll I wouldn't (likely) be allowed to hang
around here actively :-)
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@... <mailto:jose%40josecgomez.com>
http://www.josecgomez.com
<http://www.usdoingstuff.com>
On Thu, Jul 11, 2013 at 1:40 PM, Mike Numbers <mnumbers@...
Behalf Of Marco Vissuet
<mailto:mvissuet%40pacificcontours.com>
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
Calvin Dekker
Â
Calvin Dekker
630-672-7688 x1484
Behalf Of
Jose Gomez
To: Vantage
*Jose C Gomez*
*Software Engineer*
> **<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com
> A BIG THANK YOU.
> FYI, when I right clicked and got the parameters, the field came back
> as %employeeID%. When I used this I again got an error, so I put a
> single quote around this and tried to clock in and got my halt.
> Jose, I hope you are on Epicor's payroll. You have helped me and lots
> of others make their product more useful.
> Thanks again for your help and your time.
> Mike
> Behalf Of Jose Gomez<mailto:jose%40josecgomez.com>
> Sent: Thursday, July 11, 2013 1:27 PM
> To: Vantage
> They should show up as parameters in the Method Directive. RIght Click
> -> Paramaters -> etc..
> *Jose C Gomez*
> *Software Engineer*
> http://www.josecgomez.com<mailto:mnumbers%40cignys.com> <mailto:mnumbers%40cignys.com>> wrote:
> On Thu, Jul 11, 2013 at 1:19 PM, Mike Numbers <mnumbers@...
> > How do I confirm that? According to my trace it lists 2 params,
> > employeeid and shift under BO.EmpBasic Method Clockin (see in my
> > 12:59 post). Is there somewhere else I can check?
> > Sent: Thursday, July 11, 2013 1:16 PM
> > To: Vantage
> > Did you verify that EmployeeID is indeed a paramter in your Method?
> > *Jose C Gomez*
> > *Software Engineer*
> > On Thu, Jul 11, 2013 at 1:07 PM, Mike Numbers <mnumbers@...
> wrote:<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com
> > > I tried that first and get the following error when I check query.
> > > employeeID must be a quoted constant or an unabbreviated,
> > > unambiguous buffer/field reference for buffers known to query .
> > > (7328)
> > > Sent: Thursday, July 11, 2013 1:02 PM
> > > To: Vantage
> > > don't put it in quotes its a variable.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > http://www.josecgomez.com<mailto:mnumbers%40cignys.com>>
> > > On Thu, Jul 11, 2013 at 12:59 PM, Mike Numbers
> > > <mnumbers@... <mailto:mnumbers%40cignys.com>
> > > wrote:halt.
> > > > If I am understanding the trace, the parm is EmployeeID.
> > > > <tracePacket>
> > > > <businessObject>Epicor.Mfg.BO.EmpBasic</businessObject>
> > > > <methodName>ClockIn</methodName> <returnType>void</returnType>
> > > > <localTime>7/11/2013 11:15:37:4997457 AM</localTime>
> > > > <executionTime>62.3988</executionTime>
> > > > <parameters>
> > > > <parameter name='employeeID' type='System.String'
> > > > ><![CDATA[316]]></parameter>
> > > > <parameter name='shift' type='System.Int32'
> > > > ><![CDATA[22]]></parameter>
> > > > </parameters>
> > > > </tracePacket>
> > > > When I Check Query, I get the message Query is OK.
> > > > for each EmpBasic where EmpBasic.EmpID = 'employeeID'
> > > > My condition is the number of rows IS MORE THAN 0. (I used this
> > > > to verify I am getting a valid Empbasic record.) My action is a
> > > > raise
> > > exception halt.
> > > > When I clock in an employee with this in place, I do not get my
> > > > If I remove the condition, I do get the halt. (this tells me the<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com
> > > > business object is being run).
> > > > Since this is the first time I have used a parm in my condition,
> > > > I think I may still have something wrong. I did put single
> > > > quotes around
> > > the
> > > parm.
> > > > Do you see anything I am doing wrong.
> > > > On Behalf Of Jose Gomez<mailto:jose%40josecgomez.com>
> > > > Sent: Thursday, July 11, 2013 12:20 PM
> > > > To: Vantage
> > > > Param... would be the name of the parameter that is being passed
> > > > to the function, maybe EmpID not sure about your exact version.
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > <http://www.josecgomez.com/feed/> <http://www.usdoingstuff.com>
> > > > On Thu, Jul 11, 2013 at 12:14 PM, Mike Numbers
> > > > > Appreciate your help, but I am still missing something. When I
> keyed:
> > > > > for each EmpBasic where EmpBasic.EmpID = param.
> > > > > And clicked Check Query. I get an error message
> > > > > "** Unable to understand after -- "EmpBasic.EmpID =". (247)"
> > > > > Sent: Thursday, July 11, 2013 12:03 PM
> > > > > To: Vantage
> > > > > Not sure what you mean about how do you use the params... you
> > > > > can use them in any 4GL like this
> > > > > FOR EACH table WHERE table.Field = param:
> > > > > END.
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > On Thu, Jul 11, 2013 at 11:55 AM, Mike Numbers
> > > > > > Labor.getrows is in my trace, but the ttLaborHed is not
> > > > > > changed or added when I clock in / out.
> > > > > > [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>] On
> > > > > > Sent: Thursday, July 11, 2013 11:40 AM<mailto:vantage%40yahoogroups.com>
> > > > > > Subject: RE: [Vantage] BPM on Clock in / Clock out<mailto:mvissuet%40pacificcontours.com>
> > > > > > Why don't you try the "Labor" business object...
> > > > > > Marco Vissuet
> > > > > > Systems Engineer
> > > > > > Pacific Contours Corporation Cell (619)507-2311 Anaheim
> > > > > > Office (714) 693-1260 San Diego Office (619)670-3900 Fax
> > > > > > (714) 693-1252 mvissuet@...
> > > > > > <mailto:mvissuet%40pacificcontours.com><mailto:marcov%40pacificcontours.com> <mailto:marcov%40pacificcontours.com>
> > > > > > <mailto:marcov@...
> > > > > > <mailto:marcov%40pacificcontours.com> ><mailto:vantage%40yahoogroups.com>
> > > > > > http://www.pacificcontours.com/
> > > > > > "The information contained herein may be subject to the
> > > > > > International Traffic in Arms Regulations (ITAR) Warning: -
> > > > > > This document contains data whose export is restricted by
> > > > > > the Arms Export Control Act (Title 22, U.S.C., Sec 2751, et
> > > > > > seq.) as amended, or the Export Administration Act (Title
> > > > > > 50, U.S.C., App
> > > > > > 2401 et seq.) as
> > > > amended.
> > > > > > Violations of these export laws are subject to severe
> > > > > > criminal and civil penalties. Disseminate in accordance with
> > > > > > provisions of DoD Directive 5230.25.
> > > > > > <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> > > > > > ] On
> > > > > > Behalf Of mike.numbers
> > > > > > Sent: Thursday, July 11, 2013 8:37 AM
> > > > > > <mailto:vantage%40yahoogroups.com>this.
> > > > > > Subject: [Vantage] BPM on Clock in / Clock out
> > > > > > 9.04.507A
> > > > > > I am trying to create a Method Directive when an employee
> > > > > > clocks in and clocks out. My trace shows empbasic.clockin
> > > > > > and empbasic.clockout are being run. When I try to pull the
> > > > > > employee num for the directive, I cannot find any tt tables
> > > > > > available. Is there a way I can pull the employee num so I
> > > > > > can run my BPMs at these
> > > times?
> > > > > > ttCallcontextbpmdata is available. I am not sure how to use
> > > > > > I checked character01 and<http://groups.yahoo.com/group/vantage/files/>
> > > > > > shortchar01 to see if the employee num was stored here, but
> > > > > > I did not see it.
> > > > > to enable
> > > access.
> > > > > (2) To search through old msg's goto:<http://groups.yahoo.com/group/vantage/files/>
> > > > enable
> > access.
> > > enable
> access.
> > > (2) To search through old msg's goto:access.
> > )<http://groups.yahoo.com/group/vantage/files/>
> (2) To search through old msg's goto:[Non-text portions of this message have been removed]
