DEFINE VARIABLE hSalesOrder AS HANDLE NO-UNDO.
DEFINE VARIABLE miscCode AS CHARACTER NO-UNDO.
DEFINE VARIABLE icustnum as integer no-undo.
DEFINE VARIABLE iordernum as integer no-undo.
{lib/PublishInfoMsg.i &InfoMsg = "'Test1'"}.
for each ttorderhed where ttorderhed.TermsCode='CC'.
assign iOrderNum=ttorderhed.OrderNum.
{lib/PublishInfoMsg.i &InfoMsg = "'Test2'"}.
RUN bo/SalesOrder.p PERSISTENT SET hSalesOrder.
FOR EACH Customer WHERE Customer.Company=CUR-COMP AND
Customer.CustNum= ttorderhed.CustNum.
Assign miscCode = Customer.ShortChar01.
END.
RUN GetByID IN hSalesOrder(INPUT iOrderNum,
{&output_dataset_SalesOrderDataSet}).
RUN GetNewOrderMsc in
hSalesOrder({&input-output_dataset_SalesOrderDataSet}, iOrderNum,0).
FOR EACH ttOHOrderMsc WHERE ttOHOrderMsc.RowMod='A':
Assign ttOHOrderMsc.MiscCode='FRGT'.
END.
RUN ChangeMiscCode in
hSalesOrder({&input-output_dataset_SalesOrderDataSet},INPUT
'OHOrderMsc').
ttOHOrderMsc.FreqCode='E'.
ttOHordermsc.DocMiscAmt= ttOHordermsc.DocMiscAmt + 10.
END.
RUN Update in hSalesOrder({&input-output_dataset_SalesOrderDataSet}).
Decorate your code with message '1` 2 3 etc... this will put entries in
your app server log then you can see exactly where the error j is
happening. Message boxes won't work for this
> Ok. but No luck yet. Tried following: same error.
> END.
> END.
> 'OHOrderMsc').
> END.
> DELETE OBJECT hSalesOrder.
> end.
> On Jun 7, 2013 4:45 PM, "sanjay219@..." <sanjay219@...>
>> END.
>> END.
>> 'OHOrderMsc').
>> END.
>> end.
message '1'.
for each ttorderhed where ttorderhed.TermsCode='CC':
message '2'.
message '3'.
message '4'.
END.
message '5'.
message '6'.
message '7'.
END.
message '8'.
'OHOrderMsc').
message '9'.
END.
message '10'.
message '11'.
Error Detail
Message: Record not found.
Type: Error
Program: Server/bo/SalesOrder.p
Method: GetByID
Table: OrderHed
Row:
Field:
Stack Trace
at Epicor.Mfg.Proxy.SalesOrderImpl.Update(SalesOrderDataSet ds)
at Epicor.Mfg.UI.Adapters.SalesOrderAdapter.Update()
at Epicor.Mfg.UI.App.SalesOrderEntry.Transaction.Update()
Also, when I open an existing order and add a new line, no error is showing up.(Also, no misc charge line is created).
What does that mean? Is that because when we create a new order, the ordernum is set to zero till it is saved. So, no value is added to iordernum.?? So, How can I check if a value is passed to iordernum?
By the time you add a line the order header has been saved.
Sent from my U.S. Cellular® Smartphone
-------- Original message --------
Date: 06/10/2013 9:14 AM (GMT-06:00)
Subject: [Vantage] Re: BPM on ORDER MISC
Yeah this should iony fire when there is a new line not in the intial save.
If there is no error when you open an existing order check the log and see
how many messages are you gettting and how far.
> Sent from my U.S. Cellular� Smartphone
> From: sanjay219@...
message '1'.
message '2'.
assign iOrderNum = ttorderhed.OrderNum.
{lib/PublishInfoMsg.i &InfoMsg = iordernum}.
message '3'.
message '4'.
Customer.CustNum= ttorderhed.CustNum:
END.
message '5'.
message '6'.
message '7'.
END.
message '8'.
'OHOrderMsc').
message '9'.
END.
message '10'.
message '11'.
Hmm is your terms code CC? on those orders? You can't do this in pre
processing if its the first time you save the order you'll have to move it
to Post Proc... Move it to post proc and try again.
i moved it to post-processing. This Time its new error :(
OHOrderMsc record not available.
Exception caught in: Epicor.Mfg.BO.SalesOrder
Error Detail
Message: OHOrderMsc record not available.
Type: Error
Method: ChangeMiscCode
Table: OHOrderMsc
Row:
Field:
Stack Trace
