I have a question. Why are we using OHOrderMsc instead of OrderMsc??
I have OrderMsc.MiscCode 'FRGT' for freight.
> **[Non-text portions of this message have been removed]
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> because that's the name of the trable in 9 not sure in 8. Do a trace and
> send it in. I want to see if tis the same in 8. Do a trace with show
> changes only and remove the irrelevant stuff please.
> *Jose C Gomez*
> *Software Engineer*
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> <http://www.usdoingstuff.com>
> *Quis custodiet ipsos custodes?*
> On Mon, Jun 10, 2013 at 10:54 AM, sanjay219@...
> Can I send you the trace log file to your email??
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> Sure. I just uploaded the file to File area. Please take a look. Thanks.
> Ok. I tried. Application Error. But, I guess we are much closer!! :)
> Error Detail
> Failed to enable constraints. One or more rows contain values violating
> non-null, unique, or foreign-key constraints.
> Table: OrderDtl
> Company='' OrderNum='0' OrderLine='0' RowIdent='': ForeignKeyConstraint
> OrderHedOrderDtl requires the child key values (, 0) to exist in the parent
> table.
> Stack Trace
> at Epicor.Mfg.Pro.Convert.copyDataTable(DataTable sourceDT, DataTable
> targetDT)
> at Epicor.Mfg.Pro.Convert.ToDataSet(ParameterSet parameters, DataSet ds,
> Int32 paramPos)
> at Epicor.Mfg.Proxy.SalesOrderImpl.Update(SalesOrderDataSet ds)
> at Epicor.Mfg.UI.Adapters.SalesOrderAdapter.Update()
> at Epicor.Mfg.UI.App.SalesOrderEntry.Transaction.Update()
> Inner Exception
> Inner Stack Trace
> at System.Data.DataSet.FailedEnableConstraints()
> at System.Data.DataSet.EnableConstraints()
> at System.Data.DataSet.set_EnforceConstraints(Boolean value)
> at System.Data.DataTable.EndLoadData()
> targetDT
> App server log:
> [13/06/10@11:18:35.334-0400] P-002948 T-005100 1 AS -- (Procedure:
> 'UpdatePost30_A1 bo/SalesOrder.p' Line:6430) 1
> 'UpdatePost30_A1 bo/SalesOrder.p' Line:6434) 2
> 'UpdatePost30_A1 bo/SalesOrder.p' Line:6467) 3
> [13/06/10@11:18:35.381-0400] P-002948 T-005100 1 AS -- (Procedure:
> 'UpdatePost30_A1 bo/SalesOrder.p' Line:6471) 4
> [13/06/10@11:18:35.397-0400] P-002948 T-005100 1 AS -- (Procedure:
> 'UpdatePost30_A1 bo/SalesOrder.p' Line:6478) 5
> [13/06/10@11:18:36.006-0400] P-002948 T-005100 1 AS -- (Procedure:
> 'UpdatePost30_A1 bo/SalesOrder.p' Line:6483) 6
> [13/06/10@11:18:36.022-0400] P-002948 T-005100 1 AS -- (Procedure:
> 'UpdatePost30_A1 bo/SalesOrder.p' Line:6488) 7
> 'UpdatePost30_A1 bo/SalesOrder.p' Line:6494) 8
> [13/06/10@11:18:36.053-0400] P-002948 T-005100 1 AS -- (Procedure:
> 'UpdatePost30_A1 bo/SalesOrder.p' Line:6500) 9
> 'UpdatePost30_A1 bo/SalesOrder.p' Line:6507) 10
> [13/06/10@11:18:36.428-0400] P-002948 T-005100 1 AS -- (Procedure:
> 'refreshttOrderDtl Server/bo/SalesOrder.p' Line:135265) Source element of a
> BUFFER-COPY statement has no record. (5365)
> [13/06/10@11:18:36.615-0400] P-002948 T-005100 1 AS -- (Procedure:
> 'UpdatePost30_A1 bo/SalesOrder.p' Line:6512) 11
> [13/06/10@11:18:36.834-0400] P-002948 T-005100 1 AS -- (Procedure:
> 'UpdatePost30_A1 bo/SalesOrder.p' Line:6517) 12
> 'UpdatePost30_A1 bo/SalesOrder.p' Line:6521) 13
> SalesOrder.update Post-Process.
> DEFINE VARIABLE hSalesOrder AS HANDLE NO-UNDO.
> DEFINE VARIABLE miscCode AS CHARACTER NO-UNDO.
> DEFINE VARIABLE icustnum as integer no-undo.
> DEFINE VARIABLE iordernum as integer no-undo.
> message '1'.
> for each ttorderhed where ttorderhed.TermsCode='CC':
> message '2'.
> assign iOrderNum = ttorderhed.OrderNum.
> {lib/PublishInfoMsg.i &InfoMsg = iordernum}.
> message '3'.
> RUN bo/SalesOrder.p PERSISTENT SET hSalesOrder.
> message '4'.
> FOR EACH Customer WHERE Customer.Company=CUR-COMP AND
> Customer.CustNum= ttorderhed.CustNum:
> Assign miscCode = Customer.ShortChar01.
> END.
> message '5'.
> RUN GetByID IN hSalesOrder(INPUT iOrderNum,
> {&output_dataset_SalesOrderDataSet}).
> message '6'.
> RUN GetNewOrderMsc in
> hSalesOrder({&input-output_dataset_SalesOrderDataSet}, iOrderNum,0).
> message '7'.
> FOR EACH ttOrderMsc WHERE ttOrderMsc.RowMod='A':
> Assign ttOrderMsc.MiscCode='FRGT'.
> END.
> message '8'.
> RUN ChangeMiscCode in
> hSalesOrder({&input-output_dataset_SalesOrderDataSet},INPUT
> 'OrderMsc').
> message '9'.
> ttOrderMsc.FreqCode='E'.
> ttordermsc.DocMiscAmt= ttordermsc.DocMiscAmt + 10.
> END.
> message '10'.
> RUN Update in hSalesOrder({&input-output_dataset_SalesOrderDataSet}).
> message '11'.
> message '12'.
> DELETE OBJECT hSalesOrder.
> message '13'.
> end.
> Yes. Only line 1. But its taking too much time after we add new line.
> Seems, its stuck on 'Saving Data...'
On Mon, Jun 10, 2013 at 11:54 AM, Jose Gomez <jose@...> wrote:
> Did you change it to line 1? how far did it get in the messages?
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> <http://www.josecgomez.com/professional-resume/> <http://www.josecgomez.com/feed/>
> On Mon, Jun 10, 2013 at 11:51 AM, sanjay219@... <sanjay219@...
> What's the port number you are using to run this? 8301 8321 or 8331?
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> 8321
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> That's because its going through an infinite loop. Set CheckBox01 or
> something like that on SalesORderHead after processing and make that a
> condition on the BPM.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> On Mon, Jun 10, 2013 at 12:00 PM, sanjay219@...
> > 8321
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> > > > On Mon, Jun 10, 2013 at 11:51 AM, sanjay219@ <sanjay219@
----- Original Message -----
To: "Vantage" <vantage@yahoogroups.com>
Sent: Monday, June 10, 2013 11:02:38 AM
Subject: Re: [Vantage] Re: BPM on ORDER MISC
*Jose C Gomez*
*Software Engineer*
E: jose@...
> 8321
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> Sorry, I didnt get you, Can you please explain it?
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > 8321
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@
> line.
