I am testing to apply an upgrade to Kinetic 2023.2.5, I have this error/exception in each table where I have a simple ChangeLog data directive, this occurs only in my “production” database, in the demo database the BPM works correctly :
## System Information ##
AppServer Connection: https://myservername.mydomainname/KNTCLive
Form Name: AR Invoice Entry
Customization Name: csgInvoiceEntry
Menu ID: CSG121
Software Version: 11.2.400.0
Server Side Exception
BPM runtime caught an unexpected exception of 'BLException' type.
See more info in the Inner Exception section of Exception Details.
## Error Detail ##
##!Correlation ID:##! 288481bb-6bae-45cd-a7c1-24a62658222b
##!Description:##! BPM runtime caught an unexpected exception of 'BLException' type.
##!Inner Exception:##! Error accessing the database: Timeout expired. The timeout period elapsed prior to completion of the operation or the server is not responding.
Operation cancelled by user.
The statement has been terminated.
The wait operation timed out.
##!Program:##! Epicor.Ice.dll
##!Method:##! UpdateActivity
##!Line Number:##! 162
##!Column Number:##! 9
##!Server Trace Stack:##! at Ice.Tracking.ActivityTracker.UpdateActivity(ActivityEvent activityEvent, SysActivityTracker sysActivityTracker) in C:\_releases\ICE\ICE4.2.400.5\Source\Server\Framework\Epicor.Ice\Tracking\ActivityTracker.cs:line 162
at Epicor.Customization.Bpm.BpmActivityTracker.Log(DirectiveDescription directiveDesc, String userId, String activityId) in C:\_releases\ICE\ICE4.2.400.0FW\Source\Server\Internal\Lib\Epicor.Customization.Bpm\BpmActivityTracker.cs:line 29
Inner Trace:
: at Ice.Lib.SolutionTracker.ExecSqlCommand(SqlCommand cmd, SqlConnection sqlCnx) in C:\_releases\ICE\ICE4.2.400.0FW\Source\Server\Internal\Lib\SolutionTracker\SolutionTracker.cs:line 83
at Ice.Triggers.Default.WriteTrigger`2.Write(TRec newRecord, TRec oldRecord) in C:\_releases\ICE\ICE4.2.400.0FW\Source\Server\Db\Triggers\Default\Write.cs:line 22
at Ice.DataTrigger`2.Ice.ILinqTrigger.Write(LinqRow newRecord, LinqRow oldRecord) in C:\_releases\ICE\ICE4.2.400.5\Source\Server\Framework\Epicor.Ice\Triggers\TriggerBase.cs:line 21
at Ice.Triggers.TriggerQueue.ExecuteWriteTrigger(IceDataContext context, LinqRow modifiedRecord, LinqRow originalRecord) in C:\_releases\ICE\ICE4.2.400.0FW\Source\Server\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 305
at Ice.Triggers.TriggerQueue.RunWriteTriggerInNewLevel(IceDataContext context, LinqRow modifiedRecord, LinqRow originalRecord, Boolean forAddedRow) in C:\_releases\ICE\ICE4.2.400.0FW\Source\Server\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 180
at Ice.Triggers.TriggerQueue.<>c__DisplayClass9_0.<RunWriteTrigger>b__1() in C:\_releases\ICE\ICE4.2.400.0FW\Source\Server\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 147
at Ice.Triggers.TriggerQueue.RunAtNewLevel(Func`1 buildTriggerRunState, Action action) in C:\_releases\ICE\ICE4.2.400.0FW\Source\Server\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 508
at Ice.Triggers.TriggerQueue.RunTriggers(IceDataContext context) in C:\_releases\ICE\ICE4.2.400.0FW\Source\Server\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 76
at Ice.IceDataContext.RunUntilAllTriggersHaveExecuted() in C:\_releases\ICE\ICE4.2.400.0FW\Source\Server\Framework\Epicor.System\Data\IceDataContext.cs:line 527
at Ice.IceDataContext.Validate[TLinqRow](TLinqRow row) in C:\_releases\ICE\ICE4.2.400.0FW\Source\Server\Framework\Epicor.System\Data\IceDataContext.cs:line 292
: at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, SqlDataReader ds)
at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, Boolean sendToPipe, Int32 timeout, Boolean asyncWrite, String methodName)
at System.Data.SqlClient.SqlCommand.ExecuteNonQuery()
## Client Stack Trace ##
at Ice.Cloud.ProxyBase`1.CallWithCommunicationFailureRetry(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, RestRpcValueSerializer serializer)
at Ice.Cloud.ProxyBase`1.CallWithMultistepBpmHandling(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, Boolean useSparseCopy)
at Ice.Cloud.ProxyBase`1.Call(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, Boolean useSparseCopy)
at Erp.Proxy.BO.ARInvoiceImpl.UpdateMaster(ARInvoiceDataSet ds, String cGroupID, String cTableName, Boolean runCheckAmortSched, Boolean runChkLtrOfCredit, Boolean& genAmortSched, Boolean lRASchedExists, Int32 ipInvoiceNum, Int32 ipInvoiceLine, String cARLOCID, Boolean suppressUserPrompts, Decimal dTotalCharges, Boolean lGetDefaultAccount, Decimal& grpTotalInvAmt, String& opGenMessage, String& opLtrCrdMsg, Boolean& lUpdateRan)
at Erp.Adapters.ARInvoiceAdapter.UpdateMaster(String cGroupID, String cTableName, Boolean runCheckAmortSched, Boolean runChkLtrOfCredit, Boolean& genAmortSched, Boolean lRASchedExists, Int32 ipInvoiceNum, Int32 ipInvoiceLine, String cARLOCID, Boolean suppressUserPrompts, Decimal dTotalCharges, Boolean lGetDefaultAccount, Decimal& grpTotalInvAmt, String& opGenMessage, String& opLtrCrdMsg, Boolean& lUpdateRan)
at Erp.Adapters.ARInvoiceAdapter.UpdateMasterUsingPasteInsert(String cGroupID, String cTableName, Boolean runCheckAmortSched, Boolean runChkLtrOfCredit, Boolean& genAmortSched, Boolean lRASchedExists, Int32 ipInvoiceNum, Int32 ipInvoiceLine, String cARLOCID, Boolean suppressUserPrompts, Decimal dTotalCharges, Boolean lGetDefaultAccount, Decimal& grpTotalInvAmt, String& opGenMessage, String& opLtrCrdMsg, Boolean& lUpdateRan, String pasteInsertColumnsToValidate)
at Erp.UI.App.ARInvoiceEntry.Transaction.Update(Boolean refreshGroup)
## Inner Exception ##
Unable to update activity with type: '1'. ActivityID: 'BPM' Key1: '00373518-19f7-4067-933e-5132d7841d16'
