BPM that can delete a Record
Yes Call teh Business Object Delete from the BPM.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Fri, Feb 11, 2011 at 4:16 PM, scottinct78 <spare@...>wrote:
> Is it possible for BPM to delete a record? I want to delete all 25,000+
> records in one of my UD## tables. Of if there is a better way to do it I am
> all ears?
Is it possible for a BPM to delete a record? I tried to create an Pre action with 4GL code that was something like this.
for each UD01 where ud01.company = cur-comp.
run lib\updatetablebuffer.p(input BUFFER UD01:HANDLE, 'RowMod','d').
END.
I was able to get this code to set checkbox01 to true for every record, but it would not delete the records.
Is this possible? I was trying to clean up 29,000 records in UD01, and Service Connect is a slow pain in the butt.
Any suggestions would be helpful.
You could delete these directly via ODBC (Progress) or SQL Admin
Studio (delete from dbo.ud01 where company = 'whatever'). The UD tables
are completely safe to manipulate in this way.
If you have the updated Progress 'development kit' license (which you
can get free from your CAM) you can also issue a DELETE statement in
4GL.
-bws
Of scottinct78
Sent: Wednesday, February 09, 2011 9:21 PM
Subject: [Vantage] BPM that can delete a Record
'RowMod','d').
END.
If you call a Business Object from your BPM you can delete the record
without even having to bypass the business logic.
On Thu, Feb 10, 2011 at 9:53 AM, Brian W. Spolarich <
> 4GL.
> -bws
> Of scottinct78
> 'RowMod','d').
> END.
It can if you have the proper progress license installed. Do you have
an SQL database? If its just a UD table I wouldn't hesitate to use an
SQL statement to nuke the records. Or if you want to dump the entire
table, just truncate it.
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of scottinct78
Sent: Wednesday, February 09, 2011 8:21 PM
END.
I'd second your mention of UD tables. I'd be VERY hesitant to start zapping
records on any of the Epicor tables without using a BO. Things can get ugly
very quickly if you miss something.
> Rob Bucek
> FAX: (715)284-4084
> Of scottinct78
> END.
I have a process that will use the get rows that meet criteria, save them for log output, then delete them (archive and delete process) - for UD02. I do this each week. I just checked the time in service connect and for 34 records it took 9 seconds...
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of scottinct78
END.
Is it possible for BPM to delete a record? I want to delete all 25,000+ records in one of my UD## tables. Of if there is a better way to do it I am all ears?
