event on the load where you assign the value = 0 for your
checkboxes.
*Amélie Pelletier*
*Analyste Programmeur / Program analyst*
[image: cid:image001.jpg@01CD5525.2091A820]
*230, Boulevard Nilus-Leclerc*
*L'Islet, Québec (Canada)*
*G0R 2C0*
*Téléphone: 418-247-3986 ext. 2390*
*Fax: 418-247-7925*
*amelie.pelletier@... <brigitte.savoie@...>*
*P* Est-ce nécessaire d’imprimer ce message?
*Please consider the environment before printing this email**.*
*De :* vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]
*Envoyé :* 4 décembre 2014 10:44
*À :* vantage@yahoogroups.com
*Objet :* [Vantage] BPM - Time Phase
Current version 9.05.702A
I am not sure if this can be done since the Time Phase is a temp table. I
need to create a BPM so when Time Phase is launched the "Suggestions" and
"Transfer order Suggestions" are unchecked by default. I just can't seem
to figure out the Method. I am using BO TimePhas.
Any help would be great.
Thanks Kim
Private Sub TimePhasForm_Load(ByVal sender As Object, ByVal args As EventArgs)
' Add Event Handler Code
Me.edvMisc = CType(Me.oTrans.EpiDataViews("Misc"),EpiDataView)
Me.edvMisc.dataView(0)("TOSuggestions") = false
Me.edvMisc.dataView(0)("Suggestions") = false
Me.edvMisc = Nothing
End Sub
I used a customization to achieve this. The form loads with the boxes checked, but when you tab off the part number field they uncheck and will remain unchecked for the duration of the use of the form.
I used a form event wizard – afteradaptermethod. The code I used is below, hopefully can set you in the right direction.
Private Sub oTrans_adapter_AfterAdapterMethod(ByVal sender As Object, ByVal args As AfterAdapterMethodArgs)
' ** Argument Properties and Uses **
' ** args.MethodName **
' ** Add Event Handler Code **
' ** Use MessageBox to find adapter method name
' EpiMessageBox.Show(args.MethodName)
Select Case args.MethodName
Case "Update"
Case Else
Dim CB01 As EpiCheckBox = CType(csm.getNativeControlReference("cdf4e0c8-4643-4c8b-9aaf-a53c47ce9985" ), EpiCheckBox)
CB01.checked = false
Dim CB02 As EpiCheckBox = CType(csm.getNativeControlReference("7ceb719a-f574-4989-bf03-18263d5719f4" ), EpiCheckBox)
CB02.checked = false'
End Select
End Sub
faepigrl@... [vantage] [mailto:vantage@yahoogroups.com]
Sent: Thursday, December 04, 2014
9:45 AM
Subject: [Vantage] BPM - Time
Phase
I am not sure if this can be done since the Time Phase is a temp table. I need to create a BPM so when Time Phase is launched the "Suggestions" and "Transfer order Suggestions" are unchecked by default. I just can't seem to figure out the Method. I am using BO TimePhas.
Thanks Kim
