BPM when MRP creates jobs
I believe in 8 that it's all run by progress procedures in the background. In 9 they did a lot of work revamping MRP, and you can intercept some things, but I think that grabbing hold of jobs as they are created on the fly by MRP is still a bit outside something that would be considered less than heroic.. You could write a BPM or a .p program and loop through the newly created jobs after MRP was completed..
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-4832
FAX: (715)284-4084
[cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of scottyk537
Sent: Monday, October 22, 2012 12:45 PM
Subject: [Vantage] BPM when MRP creates jobs
I am looking for the method that is called when MRP creates jobs.
I have a pre-process directive on the JobEntry.Update, changing the JobOper.ProdStandard field. This works great when I manually create jobs, but does not work when MRP creates jobs.
I've looked everywhere and can't seem to find the method. Does anyone know where it is?
Anyone have any other ideas that may work?
Scott
Scott
Maybe you can do a data directive for when a jobhead or joboper is added and the job begins with "mrp"
Marco Vissuet
Systems Engineering
Pacific Contours Corporation
Office (619) 670-3900
Fax (619) 670-1643
marcov@...<mailto:marcov@...>
http://www.pacificcontours.com/
"The information contained herein may be subject to the International Traffic in Arms Regulations (ITAR) Warning: - This document contains data whose export is restricted by the Arms Export Control Act (Title 22, U.S.C., Sec 2751, et seq.) as amended, or the Export Administration Act (Title 50, U.S.C., App 2401 et seq.) as amended. Violations of these export laws are subject to severe criminal and civil penalties. Disseminate in accordance with provisions of DoD Directive 5230.25.
Sent: Monday, October 22, 2012 10:45 AM
Scott
I've tried data directives and they will change the ProdStandard field, however the required quantity field does not recalculate based on the new Production Standard.
Using the pre-process directive, the required quantities are updated correctly. I just cannot find the method that MRP uses.... I've also tried UpdateExt.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Marco Vissuet
Sent: Monday, October 22, 2012 12:49 PM
Subject: RE: [Vantage] BPM when MRP creates jobs
Marco Vissuet
Systems Engineering
Fax (619) 670-1643
marcov@...<mailto:marcov%40pacificcontours.com><mailto:marcov@...<mailto:marcov%40pacificcontours.com>>
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of scottyk537
Scott
CONFIDENTIALITY: The information contained in this email message, including any attachment(s), may be privileged and confidential and protected from disclosure. The email is not intended for transmission to, or receipt by, any unauthorized persons. If the reader of this message is not the intended recipient, or an employee or agent responsible for delivering this message to the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication or use of the information contained herein is strictly prohibited. If you have received this electronic mail transmission in error, please delete it from your system without copying or disseminating, and notify the sender by Reply email, so that our address record can be corrected.
