Has anyone on E9, done something like this using BPM Data Directives? If so can you tell about your experience with Data Directives rather and BAM 4GL code?
Dan
Dan
--- In vantage@yahoogroups.com, "Brian W. Spolarich " <bspolarich@...> wrote:
> I would do a custom 4GL program on a BAM alert that looks up the buyer for a given PO watching the fields that you are interested in.
> I've included an e-mail describing a much more elaborate solution for PO approval notification below. The point is that your BAM 4GL program can call set the values of Email-To, Email-Subject, etc. and you'll get what you want.
> I don't have time to connect all the dots here, but maybe this is enough to get you started. The Vantage 8.03 Tools Guide section on Business Activity Manager has a good section on this.
> -bws
> Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
> Â Â Â Â bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of vanb1950
> Sent: Tuesday, March 16, 2010 11:46 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] BPM with dynamic email receipient
> I am trying to send an email to a user when certain fields change on a Purchase Order. I need the recipient to be the buyer that entered the Purchase Order. Can anyone offer adice on how to do this?
> Thanks,
> Van Backeris
> [Resending this from early September in case this is useful to you. -bws]
> Here's what I wound up doing:
> 1. Save the below 4GL code API-POApprovalNotification.p as a .P file under mfgsys803\server\ud\ with whatever name you want.
> 2. Create a BAM on POHeader watching for changes in ApprovalStatus and ShortChar01. Add rules, For Alert, where ApprovalStatus <> U or ShortChar01 <> "".
> 3. Create a BPM as follows:
> - POApvMsg.Update, Post-Processing
> - Condition: Number of Rows in 'GetApvMsg' query is not lets than one
> - Query: for each ttPOApvMsg where ttPOApvMsg.MsgType = '1' no-lock
> - Action: Synchronously execute 4GL Action with code below, record nothing
> - Code:
> find ttPOApvMsg.
> for each ttPOApvMsg no-lock:
> message "ttPOApvMsg.PONum: " + string(ttPOApvMsg.PONum) + "~n".
> find first POHeader where POHeader.Company = ttPOApvMsg.Company and POHeader.PONum = ttPOApvMsg.PONum no-lock.
> define variable ApprovalChain as character no-undo.
> ApprovalChain = POHeader.ShortChar01 + "/" + ttPOApvMsg.MsgTo.
> run lib\UpdateTableBuffer.p(input BUFFER POHeader:HANDLE, 'ShortChar01',ApprovalChain).
> end.
> That's it.
> The point here is that without the BPM you have no way that I could figure out how to detect when the up-level approval notification has been generated, so you'd only get an e-mail from the BAM from the initial PO approval request, not the subsequent ones. With the BPM I modify a ShortChar field in the POHeader table appending the next approver. The data is irrelevant, as long as the field changes, and thus the BAM gets triggered. This notification program sends e-mail to each approver in series (assuming their Buyer record has an e-mail address), and the requestor Buyer indicating the final disposition (approve or reject) of the PO approval request.
> I needed to use a BAM because I didn't think one could use a BPM 4GL action to send e-mail. However I saw something about this come across the list recently (although I apparently didn't save it and given how badly the search works in this Yahoo! Group not sure if I can find it again), so I think you could do this entirely as a BPM if you wanted to keep it cleaner. It seems to me that one should be able to do everything in a BPM that one can do in a BAM.
> -bws
> -----Begin API-POApprovalNotification.p-----
> {ud/GlbAlert.i &TableName = "POHeader"}
> DEFINE VARIABLE POAmount AS DECIMAL NO-UNDO.
> DEFINE VARIABLE PONumber AS DECIMAL NO-UNDO.
> DEFINE VARIABLE Company AS CHARACTER NO-UNDO.
> DEFINE VARIABLE ApprovalStatus AS CHARACTER NO-UNDO.
> DEFINE VARIABLE ApproverEmail AS CHARACTER NO-UNDO.
> DEFINE VARIABLE ApproverName AS CHARACTER NO-UNDO.
> DEFINE VARIABLE ApproverCode AS CHARACTER NO-UNDO.
> DEFINE VARIABLE RequestorEmail AS CHARACTER NO-UNDO.
> DEFINE VARIABLE RequestorName AS CHARACTER NO-UNDO.
> DEFINE VARIABLE RequestorCode AS CHARACTER NO-UNDO.
> DEFINE VARIABLE StatusText AS CHARACTER NO-UNDO.
> DEFINE VARIABLE ApprovalStatusDesc AS CHARACTER NO-UNDO.
> PONumber = POHeader.PONum.
> Company = POHeader.Company.
> ApprovalStatus = POHeader.ApprovalStatus.
> message "In API-POApprovalNotification.p: Company: " + Company + " PONumber: " + string(PONumber) + " ApprovalStatus: " + ApprovalStatus + "~r~n".
> find PODetail where (PODetail.Company = POHeader.Company) and (PODetail.PONum = POHeader.PONum) no-lock no-error.
> for each PODetail of POHeader:
> POAmount = POAmount + (PODetail.DocUnitCost * PODetail.OrderQty).
> end.
> find POApvMsg where (POApvMsg.Company = POHeader.Company) and (POApvMsg.PONum = POHeader.PONum) no-lock no-error.
> if available POApvMsg then do:
> case POApvMsg.MsgType:
> when "1" then do:
> find PurAgent where (PurAgent.Company = POHeader.Company) and (PurAgent.BuyerId = POApvMsg.MsgTo) no-lock no-error.
> ApproverName = PurAgent.Name.
> ApproverEmail = PurAgent.EmailAddress.
> ApproverCode = PurAgent.BuyerID.
> find PurAgent where (PurAgent.Company = POHeader.Company) and (PurAgent.BuyerID = POApvMsg.MsgFrom) no-lock no-error.
> RequestorName = PurAgent.Name.
> RequestorEmail = PurAgent.EmailAddress.
> RequestorCode = PurAgent.BuyerID.
> end.
> when "2" then do:
> end.
> end case.
> case ApprovalStatus:
> when "A" then do:
> StatusText = "Has Been Approved!".
> ApprovalStatusDesc = "Approved".
> Assign Email-To = RequestorEmail.
> end.
> when "R" then do:
> StatusText = "Has Been Denied!".
> ApprovalStatusDesc = "Rejected".
> end.
> when "P" then do:
> StatusText = "Requires Approval...".
> ApprovalStatusDesc = "Pending Approval".
> Assign Email-To = ApproverEmail.
> Assign Email-CC = RequestorEmail.
> end.
> when "U" then do:
> message "Not sending e-mail for ApprovalStatus = U".
> Assign SendEmail = False.
> end.
> end case.
> message "Email-To: " + Email-To + "~nEmail-CC: " + Email-CC.
> Assign Email-To = "bspolarich@...".
> Assign Email-CC = "bspolarich@...".
> find Vendor where (Vendor.Company = POHeader.Company) and (Vendor.VendorNum = POHeader.VendorNum) no-lock no-error.
> Assign Email-From = "vantage-alerts@...".
> Assign Email-Subject = POHeader.Company + " Purchase Order Approval Status Notification".
> Assign Email-Text = "Purchase Order " + string(POHeader.PONum) + " " + StatusText + "~r~n"
> + "----------~r~n"
> + "Company: " + POHeader.Company + "~r~n"
> + "Vendor: " + Vendor.Name + " (" + Vendor.VendorID + ")~r~n"
> + "PO Amount: " + TRIM(string(POAmount, "$>>>,>>>,>>9.99")) + "~r~n"
> + "Approval Status: " + ApprovalStatusDesc + "~r~n"
> + "Buyer: " + RequestorName + " (" + RequestorCode + ") <" + RequestorEmail + ">~r~n"
> + "PO Date: " + string(POHeader.OrderDate) + "~r~n"
> + "Approver: " + ApproverName + " (" + ApproverCode + ") <" + ApproverEmail + ">~r~n"
> + "Comments: ~r~n" + POHeader.CommentText + "~r~n".
> if (POApvMsg.MsgText <> "") then do:
> Assign Email-Text = Email-Text + "Approval Message Log: ~r~n" + POApvMsg.MsgText + "~r~n".
> end.
> message "Email-Text: ~n" + Email-Text.
> end.
> else do:
> message "Not sending e-mail.~r~n".
> return "Cancel Send".
> end.
> -----End API-POApprovalNotification.p-----
