BPM's adding fields
you don't use BPM for this.
You set epicor in developer mode from the main interface then open the form you want to customize it will ask you to chose a layer - choose the base.
The form will open and the go to menu tools/customization and it will allow you to modify your form and add fields.
When finish you have to give it a name.
Then you have to edit menu maintenance for this menu to call the customized form.
Ephraim Feldman
Programmer / Analyst
Axis Lighting
Sender: vantage@yahoogroups.com
Date: Tue, 31 May 2011 15:49:33
To: <vantage@yahoogroups.com>
Reply-To: vantage@yahoogroups.com
Subject: [Vantage] Re: BPM's adding fields
I must be doing something wrong. Let me tell you what steps I am taking. I click on BPM's off the Systems Management tab. Select Action Process under General Operations. I cant see how to load the form to add the field. I click on developer mode and nothing happens.. any ideas
--- In vantage@yahoogroups.com, Karen Schoenung <kschoenung@...> wrote:
> You need to customize the form (use developer mode)...If it is a field already available, you can use the toolbox to add a text box or number and bind it to a field that is available
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of gordon
> Sent: Tuesday, May 31, 2011 10:04 AM
> Subject: [Vantage] BPM's adding fields
> Does anybody know how to add a field to a screen/form in VISTA such as the BOL...???
