ckrusen
(Calvin Krusen)
1
I want a field for an OrderDtl record to be updated, when a different OrderDtl record (but for same Company & OrderNum) is changed.
Pretend that OrderQty of line 2 must always be twice the OrderQty of line 1.
If OrderQty of line 1 changes, then I need to set OrderQty of line 2 to 2x line 1’s OrderQty.
And if line 2 changes, then I need to set OrderQty of line 1 to 1/2 of line 2’s OrderQty.
How would you address this? BPM (Pre-Proc or Post-Proc), or DD (In-Trans or Standard)?
And most importanly, how do you make a change to the record that wasn’t changed?
BrendanW
(Brendan Woodell)
2
I’m pretty sure you can do with with a Post-Proc Method Directive on Update.
Do all of your conditions then point to a Custom Code Module. Inside might look something like:
using (var txScope = IceContext.CreateDefaultTransactionScope())
var OrderDtl_xRow = (from ThisOD in ttOrderDtl where
ThisOD.Company == Session.CompanyID &&
ThisOD.RowMod == IceRow.ROWSTATE_UPDATED
select ThisOD).FirstOrDefault();
if(OrderDtl_xRow != null)
int OL = OrderDtl_xRow.OrderLine + 1;
var OrderDtl_yRow = (from ThisOD in Db.OrderDtl where
ThisOD.OrderNum == OrderDtl_xRow.OrderNum &&
ThisOD.OrderLine == OL
if(OrderDtl_yRow != null)
OrderDtl_yRow.SellingQty = OrderDtl_xRow.SellingQty * 2m;
Db.Validate();
txScope.Complete();
If that works, you’ll probably still have to GetByID/Refresh the Order before you see any changed value in the client.
