Hi all
I am trying to write a query which will provide a substring of an order line description based on the first line feed or carriage return found in the description.
Our order line descriptions will be something like the following:
"Connect Table - 1385w x 965d - low pressure laminate
Height: 590mm
Top Colour: Energise
Edge Colour: Energise"
I want to strip out and report the first line only, i.e. up until the first carriage return. That first line will be quite variable in length.
If anybody can help with the syntax for the calculated field in the query, it would be much appreciated.
Thanks Marty
