Breaking out of nested Do/For loops in CPQ
Since Epicor does not have traditional For and Do loops, I’ve been using Count to mimic For Loops such as:
For A = B To C
IF X = Y THEN
Do Stuff here
ELSE
Exit For
END IF
Next A
In Epicor I’m just using BREAK
For A = B To C
IF X = Y THEN
Do Stuff here
ELSE
BREAK
END IF
Next A
It works good enough, but if I have a nested For (or Count in Epicor) the Break only breaks out of the nested Count, not the entire structure. Has anyone run across a similar situation? Similar to nested Do While/For Loops. In VBA it’s easy to control what/where to exit/break out. Epicor, not so much. Also no support for GoTo:.
TIA.
The second should have been the nested COUNT, not FOR:
COUNT A FROM B To C
SET FIELD decS0 (Get A)
COUNT P FROM X to Y
SET FIELD txtESVar (Get field “txtIDPurlin” + (Get P)
IF txtESVar > 100
BREAK
BREAK
So in my case, when the condition is met within the indented COUNT P and txtESVar>100, the BREAK only breaks out of that COUNT, and the COUNT A still runs.
I’ve not run into this myself yet.
I do loop through my nested CPQs but not wanted to break out of the loop. I usually do some IF statements and when a condition is met I am setting a value on the parent CPQ but I let it continue running through the loop.
Not sure if that helps?
