Ron,
That sounds like a sensible alternative, but we already use that
comments field for work instruction number identification.
The masterplan I had was to get crystal to parse the user defined
field for R1,R2,R3 etc and repeat these records out onto the job
traveller. We then have a job traveller which has a separate line per
circuit ref, but in terms of availability reports, all the part
numbers are actually grouped together in the bom.
Does this make sense to you?
Jonny
Jonny
> Jonny,field
> While I can't answer your question directly, I can tell you what we
> did. Just like you, we make electronics and the bubblenum field was
> useless to us. Instead, we're using the Manufacturing Comments
> for each Material Sequence number on the BOM. Then I modified the
> grid view to show that column instead of the bubblenum column.
> Thanks,
> Ron Cole
> IT Manager, IED Inc.
> rcole@...
> > We are an electronics company and as such, our boms can have 10's
> of
> > different bubblenums (circuit refs) for the same component.
> > In Vantage upto and including V8, the bubble field is only 10
> > characters in length! So I decided I should use another field
> which has
> > a higher character limit.
> > I've tried adding a user defined field text box
> (ECOMtl.Character01) to
> > the operation/material maintenance bits on Engineering workbench
> thru a
> > customisation. This saves fine whilst the revision is still
> checked
> > out, but once it is checked in, the ECOMtl.Character01 is blank.
> I've
> > confirmed this by then checking the revision back out again and
> sure
> > enough, the ECOMtl.Character01 field is blank again. If I modify
> the
> > bubble number field, the value stays in place thru-out all the
> checking
> > out and in, so what am I doing wrong?
> > Cheers,
> > Jonny
