We have the same issue.
And I do the regular install and then just copy the mfgsys files from the server client config folder to the client.
Ephraim
Ephraim Feldman
Sender: vantage@yahoogroups.com
Date: Tue, 7 Dec 2010 12:57:59
To: <vantage@yahoogroups.com>
Reply-To: vantage@yahoogroups.com
Subject: RE: [Vantage] Buggy Client Install
No.
Do not mess with that .zip file, there is no point to it, putting those
.mfgsys files in there will only mess things up for you, since they will be
deleted next time you do a service pack.
You're actual problem is with the way you are installing the client.
Using that .msi file isn't the way to do it, you should just copy the
Epicor905\Client folder to the location you want to install it to, the only
thing that install program does it set up the folder with the auto-update
file and then it copies all the files over the first time you run the
program.
Keep a set of Icons for your default install location and then copy those
and the client folder to your workstation when you do an install. You can
either copy direct from the server or just put it on a memory stick to copy
as well.
Joe Rojas
Sent: Tuesday, December 07, 2010 10:07 AM
I guess that is my problem. There is only one in there (default.mfgsys) and
this is the only one that works after the client install.
The others (Pilot, Test, Train) are in use but the config files are not in
the Releaseclient.zip
If I look in EPICOR904\client\config, all the correct config files are in
there. Should I just copy these config file into the Releaseclient.zip?
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
jrojas@... | www.matsinc.com Ask us about our clean, green and
beautiful matting and flooring
This message is intended only for the individual named. If you are not the
named addressee you should not disseminate, distribute or copy this e-mail.
Please notify the sender immediately by e-mail if you have received this
e-mail by mistake. Please note that any views or opinions presented in this
email are solely those of the author and do not necessarily represent those
of the company.
Of Waffqle Driggers
Sent: Tuesday, December 07, 2010 9:55 AM
Subject: Re: [Vantage] Buggy Client Install
Any configs you're using should be in there.
Ephraim
Ephraim Feldman
No.
program.
as well.
Joe Rojas
of the company.
Of Waffqle Driggers
On Tue, Dec 7, 2010 at 9:52 AM, Joe Rojas <jrojas@...> wrote:
> Thanks for the reply.
> If I look at the Releaseclient.zip that is located in the deployment
> folder, it only contains the default.mfgsys Should I add the pilot,
> test, and train configs files to this zip file?
> jrojas@... <jrojas%40matsinc.com> | www.matsinc.com Ask us
> about our clean, green and beautiful matting and flooring
> the named addressee you should not disseminate, distribute or copy
this e-mail.
> this e-mail by mistake. Please note that any views or opinions
> presented in this email are solely those of the author and do not
> necessarily represent those of the company.
> From: vantage@yahoogroups.com <vantage%40yahoogroups.com> [mailto:
> vantage@yahoogroups.com <vantage%40yahoogroups.com>] On Behalf Of
> Waffqle Driggers
> Sent: Tuesday, December 07, 2010 9:45 AM
> To: vantage@yahoogroups.com <vantage%40yahoogroups.com>
> You need to update the config files on the server. If you look at the
> deployment configs, they should match what you're seeing on your
client.
> On Tue, Dec 7, 2010 at 8:43 AM, Joe Rojas
> <jrojas@...<jrojas%40matsinc.com>>
> wrote:
> > Hi All,
> > E9.04.506A
> > When I install the E9 client, by using Epicor9Client.msi in the
> > EPICOR904 folder, everything seems to go smoothly. I then start
> > Epicor
> > 9 and the rest of the client is downloaded.
> > After it finishes, I'm finding that the config files are not
working.
> > There is only about 15 lines and when I try to start the client it
> > errors out, mainly because it doesn't have the information to find
> > the
> > server.
> > I've never had this problem before. Is there something I can fix so
> > that future client installs work as expected?
> > jrojas@... <jrojas%40matsinc.com> <jrojas%40matsinc.com> |
> > not
> this e-mail.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access.
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
