Yes, I am trying to run it on a 64 bit server. I will install it on my workstation and see what happens.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of bw2868bond
Sent: Thursday, August 28, 2008 2:01 PM
Subject: [Vantage] Re: Business Logic Tester
Are you trying to run it on the server and the server is 64 bit OS?
I recall having something like that happen when I tried to run on my
64 bit test server...
Try from a 32 bit workstation/server if that is the case
bw
bw
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Charles Carden <ccarden@...> wrote:
> I have been attempting to use the BL tester for Vantage. I select
a .dll (doesn't matter which one) and I get the following error:
> Login failed: Exception has been thrown by the target of invocation.
> Unable to connect to the AppServer.
> Details:
> Could not connect to AppServer: General Error: Could not load file
or assembly...............The system cannot find the file specified.
> I have checked my login credentials and I know they are correct. I
am using the Port Number for the Appserver (8301).
> Any help would be appreciated.
> Charles Carden
> IT Manager
> Manitex, Inc.
> +1 (512) 942-3086
> DISCLAIMER:
> This e-mail, including attachments, may include confidential and/or
proprietary information, and may be used only by the person or entity
to which it is addressed. If the reader of this e-mail is not the
intended recipient or his or her authorized agent, the reader is
hereby notified that any dissemination, distribution or copying of
this e-mail is prohibited. If you have received this e-mail in error,
please notify the sender by replying to this message and delete this
e-mail immediately.
DISCLAIMER:
This e-mail, including attachments, may include confidential and/or proprietary information, and may be used only by the person or entity to which it is addressed. If the reader of this e-mail is not the intended recipient or his or her authorized agent, the reader is hereby notified that any dissemination, distribution or copying of this e-mail is prohibited. If you have received this e-mail in error, please notify the sender by replying to this message and delete this e-mail immediately.
