C# boreader Blank Title 124086
Ok, I resolved the errors, but nothing happens.. I inserted a message box, I'm pretty sure im up against finding an exposed event? The message box never pops up..
private void edvPartPlant_EpiViewNotification(EpiDataView view, EpiNotifyArgs args)
// view.dataView[args.Row]["FieldName"]
// args.Row, args.Column, args.Sender, args.NotifyType
// NotifyType.Initialize, NotifyType.AddRow, NotifyType.DeleteRow, NotifyType.InitLastView, NotifyType.InitAndResetTreeNodes
//MessageBox.Show(args.NotifyType.ToString());
if ((args.NotifyType == EpiTransaction.NotifyType.Initialize))
if ((args.Row > -1))
String whereClause = String.Format("VendorNum={1} AND PartNum={2}",(int)edvPartPlant.dataView[edvPartPlant.Row]["VendorNum"],(int)edvPartPlant.dataView[edvPartPlant.Row]["PartNum"]);
DataSet dsp =_boReader.GetRows("VendPart",whereClause, "LeadTime");
MessageBox.Show(whereClause);
if (dsp.Tables[0].Rows.Count >0)
edvPartPlant.dataView[edvPartPlant.Row]["Number01"] = dsp.Tables[0].Rows[0]["LeadTime"];
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Rob Bucek
Sent: Monday, August 26, 2013 3:32 PM
Subject: [Vantage] C# boreader
All,
9.05.700c C# still baffles me, im still rooted in .net but am trying some new things. Im in time phase and want to query the supplier part list and bring back the lead time from there and populate the number01 field in the partplant view. I do not need to add this to the grid view. The snippet below still needs the part number in the whereclause but im not even close to getting working so far....
110 DataSet dsp =_boReader.GetRows("SupplierPart","VendorNum='" + args.Row.Cells["VendorNum"].Value.ToString() + "'", "LeadTime");
112 args.Row.Cells["Number01"].Value=dsp.Tables[0].Rows[0]["LeadTime"];
The error im getting at compile is
Error: CS0117 - line 110 (219) - 'int' does not contain a definition for 'Cells'
Error: CS0117 - line 112 (221) - 'int' does not contain a definition for 'Cells'
What am I missing?
All,
What am I missing?
