C# Customization: Defaulting Checkbox to True on Tracker
Thanks Ted!
Worked perfectly.
Hello,
I've been trying to do this all morning and I keep having an issue with :
CS0103 the name checkBox does not exist in the current context
Which I thought was bizarre.  Basically, on Form_Load I want a checkbox to default to True.
my custom code is:
private void MainController_Load(object sender, EventArgs args)
// Add Event Handler Code
epiCashHeadPosted = (Epicor.Mfg.UI.FrameWork.EpiCheckBox)csm.GetNativeControlReference("ef684526-fd74-4723-bc77-241ff775cf45");
epiCashHeadPosted = true;
So I'm guessing I'm missing a declaration somewhere but being a C# novice I'm a bit lost.
THanks for any advice.
You aren't setting the Checked property of the checkbox.
epiCashHeadPosted.Checked = true;
From: "jockthemotie@... [vantage]" <vantage@yahoogroups.com>
Sent: Friday, February 19, 2016 11:37 AM
Subject: [Vantage] C# Customization: Defaulting Checkbox to True on Tracker
Hello,
my custom code is:
Oop, thanks.
However, I still get the same error:
Error: CS0103 - line 55 (130) - The name 'epiCashHeadPosted' does not exist in the current context
 Error: CS0103 - line 56 (131) - The name 'epiCashHeadPosted' does not exist in the current context
This is how you would declare and initialize epiCashHeadPosted.
public class Script
    private EpiCheckBox epiCashHeadPosted;
        epiCashHeadPosted = (EpiCheckBox)csm.GetNativeControlReference("ef684526-fd74-4723-bc77-241ff775cf45");
        // Begin Custom Code Disposal
        // End Custom Code Disposal
        epiCashHeadPosted = null;
Sent: Friday, February 19, 2016 11:52 AM
Subject: Re: [Vantage] C# Customization: Defaulting Checkbox to True on Tracker
#ygrps-yiv-103945846 #ygrps-yiv-103945846yiv6329426950 #ygrps-yiv-103945846yiv6329426950 --
#ygrps-yiv-103945846yiv6329426950 .ygrps-yiv-103945846yiv6329426950ygrp-photo-title{
clear:both;font-size:smaller;height:15px;overflow:hidden;text-align:center;width:75px;}
#ygrps-yiv-103945846 #ygrps-yiv-103945846yiv6329426950 div.ygrps-yiv-103945846yiv6329426950ygrp-photo{
background-position:center;background-repeat:no-repeat;background-color:white;border:1px solid black;height:62px;width:62px;}
#ygrps-yiv-103945846 #ygrps-yiv-103945846yiv6329426950 div.ygrps-yiv-103945846yiv6329426950photo-title
a,
#ygrps-yiv-103945846 #ygrps-yiv-103945846yiv6329426950 div.ygrps-yiv-103945846yiv6329426950photo-title a:active,
#ygrps-yiv-103945846 #ygrps-yiv-103945846yiv6329426950 div.ygrps-yiv-103945846yiv6329426950photo-title a:hover,
#ygrps-yiv-103945846 #ygrps-yiv-103945846yiv6329426950 div.ygrps-yiv-103945846yiv6329426950photo-title a:visited {
text-decoration:none;}
#ygrps-yiv-103945846 #ygrps-yiv-103945846yiv6329426950 div.ygrps-yiv-103945846yiv6329426950attach-table div.ygrps-yiv-103945846yiv6329426950attach-row {
clear:both;}
#ygrps-yiv-103945846 #ygrps-yiv-103945846yiv6329426950 div.ygrps-yiv-103945846yiv6329426950attach-table div.ygrps-yiv-103945846yiv6329426950attach-row div {
float:left;}
#ygrps-yiv-103945846 #ygrps-yiv-103945846yiv6329426950 p {
clear:both;padding:15px 0 3px 0;overflow:hidden;}
#ygrps-yiv-103945846 #ygrps-yiv-103945846yiv6329426950 div.ygrps-yiv-103945846yiv6329426950ygrp-file {
width:30px;}
#ygrps-yiv-103945846 #ygrps-yiv-103945846yiv6329426950 div.ygrps-yiv-103945846yiv6329426950attach-table div.ygrps-yiv-103945846yiv6329426950attach-row div div a {
#ygrps-yiv-103945846 #ygrps-yiv-103945846yiv6329426950 div.ygrps-yiv-103945846yiv6329426950attach-table div.ygrps-yiv-103945846yiv6329426950attach-row div div span {
font-weight:normal;}
#ygrps-yiv-103945846 #ygrps-yiv-103945846yiv6329426950 div.ygrps-yiv-103945846yiv6329426950ygrp-file-title {
font-weight:bold;}
#ygrps-yiv-103945846yiv6329426950ygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-103945846 #ygrps-yiv-103945846yiv6329426950 #ygrps-yiv-103945846yiv6329426950ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-103945846 #ygrps-yiv-103945846yiv6329426950 #ygrps-yiv-103945846yiv6329426950ygrp-mkp #ygrps-yiv-103945846yiv6329426950hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-103945846 #ygrps-yiv-103945846yiv6329426950 #ygrps-yiv-103945846yiv6329426950ygrp-mkp #ygrps-yiv-103945846yiv6329426950ads {
margin-bottom:10px;}
#ygrps-yiv-103945846 #ygrps-yiv-103945846yiv6329426950 #ygrps-yiv-103945846yiv6329426950ygrp-mkp .ygrps-yiv-103945846yiv6329426950ad {
padding:0 0;}
#ygrps-yiv-103945846 #ygrps-yiv-103945846yiv6329426950 #ygrps-yiv-103945846yiv6329426950ygrp-mkp .ygrps-yiv-103945846yiv6329426950ad p {
margin:0;}
#ygrps-yiv-103945846 #ygrps-yiv-103945846yiv6329426950 #ygrps-yiv-103945846yiv6329426950ygrp-mkp .ygrps-yiv-103945846yiv6329426950ad a {
color:#0000ff;text-decoration:none;}
Oop, thanks.
Error: CS0103 - line 55 (130) - The name ‘epiCashHeadPosted’ does not exist in the current context
 Error: CS0103 - line 56 (131) - The name ‘epiCashHeadPosted’ does not exist in the current context
epiCashHeadPosted = (Epicor.Mfg.UI.FrameWork.EpiCheckBox)csm.GetNativeControlReference(“ef684526-fd74-4723-bc77-241ff775cf45”);
