Calculating WIP Costs
Thanks a tough nut to crack. I've come close a couple times but never been to get it exact. Be mindfull of the closed/reopened and posted jobs. These costs will have been moved off and the calc will need to restart on the reopen date.
PartTran,JobHead,JobAsm,JobOpr,LaborDtl,Resource,RescGrp plus some others I can't remember of the top of my head.
--- In vantage@yahoogroups.com, "dswmaom" <dwalker@...> wrote:
> I am trying to create a BAQ that calculates WIP costs that mirror the standard Work In Process Report costs.
> Can anyone point me in the right direction in terms of tables, fields to use to accumulate the WIP costs?
> Thx,
> Dale.
Thx,
Dale.
I am working on the same, but not back to it recently. There are many
tables and calcs, Help in Vantage lists alot about the report.
Of dswmaom
Sent: Tuesday, January 19, 2010 3:30 PM
Subject: [Vantage] Calculating WIP Costs
Thx,
Dale.
Thanks - I just read the help text and I don't think that I can get there by using the standard BAQ, BAQRD, Crystal tools. I suspect this will require the use of SQL views and multiple work tables and I have no exposure to that type of development yet.
I looked throught the "files" section of the Yahoo Group site and didn't find any type of WIP replacement report using BAQ/Crystal tools. Does anyone have such a report that they might share?
thx,
Dale.
> Of dswmaom
> Thx,
> Dale.
There is a different way to get the WIP costs into a BAQ. Maybe you can
try the following
Link the Jobhead to jobassembl to part tran(outerjoin on jobnum)
Filter on where jobhead.wipcleared = false and jobassembl.assyseq = 0
Add up all the actual costs in the jobassembl table this will give you
costs to date for each element. (TLA + LLA)
Summarize the parttran table.
Sum costs for the following trantypes
MFG-VAR, MFG-CUS (COS amounts),
MFG-STK, (Received to stock amounts)
You will need to add job to job transaction and maybe others like
ASM-STK depending on how you are using Vantage/Epicor
The todate costs in the jobassembl minus the outgoing summarized costs
in the parttran give you the remaining WIP value
Regards
Gary
Of dswmaom
Sent: 19 January 2010 10:44 PM
Subject: [Vantage] Re: Calculating WIP Costs
thx,
Dale.
Behalf
> Of dswmaom
to
> Thx,
> Dale.
