Call 838043 - Winco Industries
I got around this by two ways.
One I modified the standard VTG files to reference a different ini file
which I call vanbase.ini, that way even if the vantage.ini is modified it
does not affect most users. Second, I found that if you change the access
permissions on the ini files to read-only for everyone (even you) then the
installs won't try (or simply can't) modify the file. Whenever you need to
make changes you simply change the permissions, make your changes and then
set them back. These methods seem to work pretty well without too much
effort.
Mercer Sisson
Sent: Monday, January 20, 2003 1:08 PM
To: Vantage Onelist (E-mail)
Subject: [Vantage] Call 838043 - Winco Industries
I don't have a document number for this one, but if you are interested give
Support a call.
Thanks Nancy
To: 'Luanne Peterson'
Subject: RE: Call 838043
SUGGESTED ENHANCEMENT:
Custom parameter is being overwritten in the Propath line of the Vantage.ini
file, (sample: PROPATH=.,W:\Custom,W:\Vantage), every time a client install
is done.
Each time a client install is ran, the Vantage.ini file must be edited so
the Custom programming will be used.
PURPOSE:
I would like to see a check box added to the Vantage, so when a client
install is done Vantage will know the Custom parameter should be put back
into the .INI file.
It's a real hassle trying to remember to put the option back in every time
there is an install. If it is forgotten the Custom programming is not used.
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=241773.2861420.4212388.1925585/D=egroupweb/S=17050071
83:HM/A=1394045/R=0/*http://www.hgtv.com/hgtv/pac_ctnt/text/0,,HGTV_3936_580
2,FF.html> HGTV Dream Home Giveaway
<http://us.adserver.yahoo.com/l?M=241773.2861420.4212388.1925585/D=egroupmai
l/S=:HM/A=1394045/rand=330118115>
Support a call.
Thanks Nancy
is done.
PURPOSE:
into the .INI file.
You could change "Vantage.ini" file property to "Read Only", it's working fine for us. The only annoying thing about it is that
every time you open Report Builder session it reminds you that "Vantage.ini" file is not writable and it will not save the changes
you make to the RB defaults.
Of course check box is great idea. May be we should ask Custom Programming to add that function if any customizations are needed.
Mike Tonoyan / All American Products Co.
E-mail: miket@...
----- Original Message -----
To: "Vantage Onelist (E-mail)" <vantage@yahoogroups.com>
Sent: Monday, January 20, 2003 10:07 AM
> Support a call.
> Thanks Nancy
> is done.
> PURPOSE:
> into the .INI file.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to
enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto:
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
We make the vantage.ini file "read only", and create another ini file
(eg vantagerb.ini) for our "Report Builder vtg" file
Sent: Monday, January 20, 2003 12:28 PM
Subject: Re: [Vantage] Call 838043 - Winco Industries
E-mail: miket@...
give
> Support a call.
> Thanks Nancy
Vantage.ini
install
> is done.
so
> PURPOSE:
back
> into the .INI file.
time
used.
enable access. )
ADVERTISEMENT
007183:HM/A=1394046/R=0/*http:/www.hgtv.com/hgtv/pac_ctnt/text/0,,HGTV_3
936_5802,FF.html> HGTV Dream Home Giveaway
pmail/S=:HM/A=1394046/rand=630272428>
<http://docs.yahoo.com/info/terms/> Terms of Service.
Britt,
Great!!! Thanks for the idea.
I just changed our Report Builder.vtg, it's working fine.
E-mail: miket@...
To: <vantage@yahoogroups.com>
Sent: Monday, January 20, 2003 11:04 AM
Subject: RE: [Vantage] Call 838043 - Winco Industries
> From: Mike Tonoyan [mailto:miket@...]
> E-mail: miket@...
> From: "Dunn, Nancy" <ndunn@...>
> give
> > Support a call.
> > Thanks Nancy
> Vantage.ini
> install
> > is done.
> so
> > PURPOSE:
> back
> > into the .INI file.
> time
> used.
> enable access. )
> ADVERTISEMENT
enable access. )
Thanks. That was too easy.
Edward F. Fox, Jr., CPA
Controller
Maxson Automatic Machinery Company
Phone: 401-596-0162 x110
Fax: 401-596-1050
www.maxsonautomatic.com
Sent: Monday, January 20, 2003 2:10 PM
Britt,
E-mail: miket@...
> E-mail: miket@...
> give
> > Support a call.
> > Thanks Nancy
> Vantage.ini
> install
> > is done.
> so
> > PURPOSE:
> back
> > into the .INI file.
> time
> used.
> enable access. )
> ADVERTISEMENT
enable access. )
