I haven’t caught up to the whole thread but may I suggest you give a look at the EpicorRest NUGET we’ve written which handles all Epicor endpoints including certificate validation and is available for
.NET 4.8
.NET 6
and .NET Standard
It is fully documented and well understood and used in hundreds of projects. It may make your life much easier.
No that’s the .NET regular version if you change your target to 4.8 you can use it otherwise there are older version available in nuget
Like I said I didn’t read the whole thread so if you are already wel on your way then you do you. But if you are still struggling this may softend the load though I would recommend upgrading to the latest version .NET 4.8
I agree, I think I went to .NET 7.0 for something else I’m using in the project. I’d rather not rip everything up at this point. BTW, is there some guide as to what the version history is for .NET?
Kevin’s solution worked! Apparently all I needed was the correct hash value, which was SHA512… @klincecum, THANK YOU for sticking with me and helping me with this project! I COULD NOT HAVE DONE IT without you!
@josecgomez, you’re ALWAYS as TERRIFIC help to me whether addressing a direct issue with me or just your brilliant answers to other questions. I owe BOTH of you a CASE of YOUR FAVORITE BEER!
If either of you are close to the SE Wisconsin area, I would LOVE to meet you guys! How can I buy you that beer?
