Trying to jump to cost adjustment screen right from part entry. It works except I get the following error both using a button click, process caller, and passing the part num or open with right click on part num. Anyone deal with this before?
Error Detail
Failed to Auto-Search; Possible invalid primary adapter defined for Epicor.Mfg.UI.CostAdjustmentEntry
Inner Exception
Object reference not set to an instance of an object.
Inner Stack Trace
at Epicor.Mfg.UI.FrameWork.EpiBaseForm.autoSubscriberSearch()
Error Detail
Inner Exception
Inner Stack Trace
