Can Epicor Create Checks From a Blank Check Stock?
A huge percentage of banks now use OCR so you don't need MICR Ink
necesarely depends on the bank
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
On Thu, Jun 27, 2013 at 11:15 AM, s1mhall <s1mhall@...> wrote:
> Correct me if I am wrong, but you would need a MICR printer/ink to print
> the MICR at the bottom of the check?
> I'm not sure what your need is for Checks, but I know in businesses I have
> worked in they have tried really hard to get their vendors and customers
> onto EFT.
> This eliminates the need for the checks and you just go with a remittance
> advice only, which can be printed and mailed, emailed as PDF or if you have
> APM (doclink) then you can send them to the ERM printer for distribution to
> the other party. (vendor,customer).
> Cheers
> Simon
> --- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@...> wrote:
> > Absolutely.
> > The only thing I needed was to acquire the MICR font so I could use it in
> > Crystal for the ABA/Routing and Acct numbers. You can get free fonts out
> > there.
> > Modify the existing Crystal check form and add your borders, bank logo,
> etc
> > and you're set. You can even scan the signature in and add it as an
> image.
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> Behalf Of
> > clederer@...
> > Sent: Thursday, June 27, 2013 10:36 AM
> > Subject: [Vantage] Can Epicor Create Checks From a Blank Check Stock?
> > We currently use Epicor to print part of the check (Check #, date, dollar
> > amount, recipient, and recipient's address). We then tell Epicor to PRINT
> > the check to a "printer" which really isn't a printer, but another
> program
> > that creates the check template, bar code, bank logo and routing numbers.
> > Is there a way to have Epicor create the entire check from a blank stock?
We currently use Epicor to print part of the check (Check #, date, dollar amount, recipient, and recipient's address). We then tell Epicor to PRINT the check to a "printer" which really isn't a printer, but another program that creates the check template, bar code, bank logo and routing numbers.
Sure Checks are nothing but Crystal Reports. Just make your report match
the Check Stock dimensions and it should work just fine.
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Thu, Jun 27, 2013 at 10:35 AM, clederer@... <
Absolutely.
there.
Modify the existing Crystal check form and add your borders, bank logo, etc
and you're set. You can even scan the signature in and add it as an image.
clederer@...
I understand the Crystal Report aspect of the form, but do you know where in Epicor to implement the necessary changes?
I guess "How do I do this?" is the question I'm asking
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
IN Company there is report Style Maintenance Program which you can open and
find the AP Check style or whichever you are looking for then you will see
it references an RPT file that is the Crystal Report file it uses, simply
find that file in your server open it in Crystal Developer and make the
desired changes
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Thu, Jun 27, 2013 at 10:49 AM, clederer@... <
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> dollar
> PRINT
> program
> numbers.
> stock?
Correct me if I am wrong, but you would need a MICR printer/ink to print the MICR at the bottom of the check?
I'm not sure what your need is for Checks, but I know in businesses I have worked in they have tried really hard to get their vendors and customers onto EFT.
This eliminates the need for the checks and you just go with a remittance advice only, which can be printed and mailed, emailed as PDF or if you have APM (doclink) then you can send them to the ERM printer for distribution to the other party. (vendor,customer).
Cheers
Simon
> Absolutely.
> there.
> clederer@...
