I cannot to see field for filtering
Anyone have any ideas on what I can do or use?
Thank you in advance.
I believe the WIP Recon report is iterative - meaning it does several cycles of processing, and isn’t just a complex query. This is why it takes so long to run.
You can’t add filters to the WIP/Recon form. But you could create a Report style
that only shows records with a Pack slip or PO num in the data.
If you want to see PO Receipts, use the following expression in row visibility
=iif(InStr(Fields!TmpReference.Value, "PS: "), false, true)
Note that would only hide the other rows from displaying, they would still be included in the G/L Account Recap section.
