Hello all,
I am writing a method to save a pdf invoice when given an invoice id. The end result will be our accounting department having an interface to email specific invoices to their contacts. The reason for making a custom interface instead of using a bulk email or bulk invoice print, is that we need each invoice to be its own pdf. This is also a pilot project of sorts as we determine how to structure our integration with Epicor objects.
The backend is using an api that is referencing a new âERPâ class library (currently just Epicor). Both of these are .NET Core 6. Iâm attempting to reuse code that works in our .NET 4.8 app (net.tcp and WCF, ARInvFormImpl and ARInvFormParam, submit to the SystemTaskAgent, write to directory.)
Despite adding what I think are the required DLLs, it continues to throw exceptions. Right now, it gets stuck in
c# var objSOForm = new Erp.Proxy.Rpt.ARInvFormImpl(netTcpBinding, svcSOForm);
throwing
System.MissingMethodException: âMethod not found: âSystem.ServiceModel.Security.X509CertificateValidationMode System.ServiceModel.Security.X509ServiceCertificateAuthentication.get_CertificateValidationMode()â.â
Source: âEpicor.Ice.Shared.Wcf.Privateâ
- Any idea what I need to add here?
- Is planning to use Epicor DLLs in .NET Core 6 doomed from the start to always run into this kind of issue?
- Are there any compatibility libraries or it possible to use .NET standard to avoid future issues?
Bonus: it doesnât appear that saving an invoice as a pdf in this way marks it as printed. Is there a param for that?
public async Task<string> PrintInvoice(int invoiceId)
var errorMessage = string.Empty;
//TODO get customerName? or use date as dir name so we can auto delete on a different day
var dirName = DateTime.Now.DayOfWeek.ToString();
var directoryPath = GetReportDirectory() + $@"{dirName}\";
Directory.CreateDirectory(directoryPath); // create directory (if not exists)
// TODO change this to be automatic
var epicorInstance = "EpicorTest";
string filePath = GetReportFilePath(invoiceId, dirName);
try
CustomBinding netTcpBinding = NetTcp.UsernameWindowsChannel();
Uri svcSOForm = new Uri("net.tcp://epicor_app/" + epicorInstance + "/Erp/Rpt/ARInvForm.svc");
Uri svcReportMonitor = new Uri("net.tcp://epicor_app/" + epicorInstance + "/Ice/BO/ReportMonitor.svc");
var creds = new CredentialHelper();
// code breaks here due to missing method exception. System.ServiceModel.Security.X509ServiceCertificateAuthentication.get_CertificateValidationMode()
objSOForm.ClientCredentials.UserName.UserName = creds.EpicorUsername;
objSOForm.ClientCredentials.UserName.Password = creds.EpicorPassword;
var datasetSOForm = new Erp.Rpt.ARInvFormDataSet();
var guid = Guid.NewGuid();
var workstationID = guid.ToString() + invoiceId.ToString();
datasetSOForm = objSOForm.GetNewParameters();
datasetSOForm.ARInvFormParam.Rows[0]["InvoiceNum"] = invoiceId;
datasetSOForm.ARInvFormParam.Rows[0]["AutoAction"] = "SSRSGenerate";
datasetSOForm.ARInvFormParam.Rows[0]["AgentID"] = "SystemTaskAgent";
datasetSOForm.ARInvFormParam.Rows[0]["SSRSRenderFormat"] = "PDF";
datasetSOForm.ARInvFormParam.Rows[0]["WorkstationID"] = workstationID;
objSOForm.SubmitToAgent(datasetSOForm, "SystemTaskAgent", 0, 0, "Erp.UIRpt.ARInvForm");
var objReportMonitor = new Ice.Proxy.BO.ReportMonitorImpl(netTcpBinding, svcReportMonitor);
objReportMonitor.ClientCredentials.UserName.UserName = creds.EpicorUsername;
objReportMonitor.ClientCredentials.UserName.Password = creds.EpicorPassword;
var datasetReportMonitor = new Ice.BO.ReportMonitorDataSet();
var startTime = DateTime.Now;
while (true)
var result = await _repository.ReportStatus.GetByWorkstationIdAsync(workstationID, false);
if (result != null)
if (result.TaskStatus == "COMPLETE")
break;
else if (result.TaskStatus == "ERROR")
objSOForm.Dispose();
objReportMonitor.Dispose();
errorMessage = "Report failed to generate.";
return string.Empty;
// if report takes too long to complete, thow an exception
if (DateTime.Now - startTime > TimeSpan.FromMinutes(3))
throw new Exception("SOA Creation timed out"); // leave while true loop
Thread.Sleep(500);
datasetReportMonitor = objReportMonitor.GetRowsKeepIdleTime($"WorkStationID = '{workstationID}'", 0, 0, out bool morePages);
objReportMonitor.Update(datasetReportMonitor);
byte[] reportBytes = objReportMonitor.GetReportBytes((Guid)datasetReportMonitor.SysRptLst.Rows[0]["SysRowID"]);
using (var reportFile = new FileStream(filePath, FileMode.Create, FileAccess.Write, FileShare.ReadWrite))
for (var i = 0; i < reportBytes.Length; i++)
reportFile.WriteByte(reportBytes[i]);
catch (Exception ex)
errorMessage = ex.Message;
return filePath;
