I will stick with NT 4.0, after all if it aint broke don't fix it.
Wouldn't do any good to try to fix anyway, Microsoft no longer supports it.
Patrick Winter
Sent: Thursday, January 08, 2004 9:05 AM
Subject: [Vantage] Re: Can not connect to vantage 4.0 running on windows 2
003 from a client pc.
Double check mapping and they are ok, gave everybody full access and
still had the same problems.
Thanks for your input,
Regards,
Doug Rowland
Patrick Winter
Regards,
Doug Rowland
--- In vantage@yahoogroups.com, Cliff Drumeller <cliff@m...> wrote:
> The quick splash screen and no more in my experience usually
indicates the
> mapping or access rights to the progress folder are not right.
Also check
> the rights on the client work directory. Just my two cents.
> Cliff Drumeller
> IT Manager
> Mass Precision Sheetmetal
> 408 954 0200
> From: Douglas Rowland [mailto:dougrowland@s...]
> Sent: Wednesday, January 07, 2004 2:58 PM
> Subject: [Vantage] Can not connect to vantage 4.0 running on
windows 2003
> from a client pc.
> I am testing windows 2003 standard server with vantage 4.00. I can
> run the client on the server, however can't connect from another
pc.
> On the same hardware I had no problems with Windows NT 4.0.
> The W2K3 server is set up only as a file server role with vantage
> running of the d: partition with the client pc having full access
> rights to both the vantage and progress directories.
> I can ping the W2K3 by both IP address and by name with no
problems,
> and can browse the vantage and progress directories from the client
> When starting vantage on the client, splash screen comes up for
only
> about 1/5 of a second then disappears.
> I compared the vantage.ini with the live system which is running
NT
> 4.0 and they are identical except for server names.
> Any suggestions would be greatly appreciated.
> Thanks in advance,
> Doug Rowland
must have
Builder and
> <http://groups.yahoo.com/group/vantage/files/.>
> <http://groups.yahoo.com/group/vantage/messages>
> <http://groups.yahoo.com/group/vantage/links>
> _____
> Yahoo! Groups Links
> * To visit your group on the web, go to:
> <http://groups.yahoo.com/group/vantage/>
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service
> <http://docs.yahoo.com/info/terms/> .
Yahoo! Groups Links
Your use of Yahoo! Groups is subject to: http://docs.yahoo.com/info/terms/
