Double check mapping and they are ok, gave everybody full access and
still had the same problems.
I will stick with NT 4.0, after all if it aint broke don't fix it.
Thanks for your input,
Regards,
Doug Rowland
Regards,
Doug Rowland
--- In vantage@yahoogroups.com, Cliff Drumeller <cliff@m...> wrote:
> The quick splash screen and no more in my experience usually
indicates the
> mapping or access rights to the progress folder are not right.
Also check
> the rights on the client work directory. Just my two cents.
> Cliff Drumeller
> IT Manager
> Mass Precision Sheetmetal
> 408 954 0200
> -----Original Message-----
> From: Douglas Rowland [mailto:dougrowland@s...]
> Sent: Wednesday, January 07, 2004 2:58 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Can not connect to vantage 4.0 running on
windows 2003
> from a client pc.
> I am testing windows 2003 standard server with vantage 4.00. I can
> run the client on the server, however can't connect from another
pc.
> On the same hardware I had no problems with Windows NT 4.0.
> The W2K3 server is set up only as a file server role with vantage
> running of the d: partition with the client pc having full access
> rights to both the vantage and progress directories.
> I can ping the W2K3 by both IP address and by name with no
problems,
> and can browse the vantage and progress directories from the client
> When starting vantage on the client, splash screen comes up for
only
> about 1/5 of a second then disappears.
> I compared the vantage.ini with the live system which is running
NT
> 4.0 and they are identical except for server names.
> Any suggestions would be greatly appreciated.
> Thanks in advance,
> Doug Rowland
must have
Builder and
> <http://groups.yahoo.com/group/vantage/files/.>
> <http://groups.yahoo.com/group/vantage/messages>
> <http://groups.yahoo.com/group/vantage/links>
> _____
> Yahoo! Groups Links
> * To visit your group on the web, go to:
> <http://groups.yahoo.com/group/vantage/>
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service
> <http://docs.yahoo.com/info/terms/> .
