You need to take a look at the aging format. That’s what dictates how the totals get applied to what bucket.
It does depend on how in depth the requirement is, but I’d start with using the apply date for each transaction to evaluate what bucket it needs to go into.
This post from the venerable @gpayne may help you with some examples
Right now, all my calculations are based on apply date and it works for 95 percent of the customers.
I assume that select by: Apply Date means that it is pulling records from the apply date.
What does Age by: Due date do to this?
In the Epicor Aged receivables report for one of the customers that is incorrect, I have two invoices. (These numbers are from 2025-03-04 when I ran the reports, BTW).
Invoice 1 has a balance of -$5.45.
The apply date is 11/6/2024
The due date is 11/6/2024
The terms are set to blank. (I calculate the buckets using the terms that the invoice are set to).
This is an Unapplied Receipt if that makes a difference.
On the report it shows in the 91-120 bucket.
In my BAQ, it shows in the 61-90 bucket.
Invoice 2 has a balance of -$87.25.
The apply date is 12/3/2024.
The due date is 12/3/2024.
The terms are blank.
This is also an unapplied receipt.
The report shows it in the 61-90 bucket.
The BAQ shows it in the 61-90 bucket.
If terms are not set, what would be Epicor’s default for the aged receivables calculation?
Does being an unapplied receipt affect it somehow?
