I solved the problem by making another vtg file called citrixvantage.vtg and
changing the temp path to J:. I use this file to run it on the server and it
works fine.
Scott Hildreth
MIS Manager
(716) 427-9050
FAX (716) 427-9051
Direct (716) 756-1460
Visit us at...
http://www.empireforster.com
works fine.
Scott Hildreth
MIS Manager
(716) 427-9050
FAX (716) 427-9051
Visit us at...
> -----Original Message-----
> From: Podlin, Michael [SMTP:michael.podlin@...]
> Sent: Wednesday, December 27, 2000 8:51 AM
> To: 'vantage@egroups.com'
> Subject: RE: [Vantage] Can this be done on MetaFrame
> Are you sure you have the drive letter mapped????
> What is your full command line you are using???
> From: Scott Hildreth [mailto:scotth@...]
> Sent: Wednesday, December 27, 2000 5:47 AM
> Michael
> I tried your hint but now I get errors (cannot find a drive mapped to
> prowin32.exe)(cannot find a drive mapped to dcd7.db) and so on.
> Scott Hildreth
> MIS Manager
> (716) 427-9050
> FAX (716) 427-9051
> Visit us at...
> > Sent: Tuesday, December 26, 2000 3:34 PM
> > Set the Citrix icon up so that the command line is the complete full
> > command
> > line. Do not use the VANTAGE.VTG file. And then set the icon up so
> that
> > the startup directory is J:\vntgwork. You will get better performance
> off
> > the citrix box using the full command line vs. the VTG file.
> > Michael Podlin
> > Sent: Tuesday, December 26, 2000 2:22 PM
> > I am trying to get Vantage to run on a Metaframe server and am having
> some
> > problems.
> > When I install the client on the server the local drive is J: so I enter
> > the
> > path( J:\vntgwork ) for the installation. It works fine on the server
> but
> > all the other clients get the message ( Unable to open
> > J:\vntgwork\lbi01448,
> > error2. (354) when trying to open it. To correct this I do a fresh
> client
> > install on a workstation of vantage using C: as the path and everything
> is
> > fine but it won't run on the server giving me the error ( Unable to open
> > C:\vntgwork\lbi01448, error2. (354)
> > any ideas?
> > Scott Hildreth
> > MIS Manager
> > (716) 427-9050
> > FAX (716) 427-9051
> > Visit us at...
> > We no longer allow attachments to files. To access/share Report Files,
> > please go to the following link: http://www.egroups.com/files/vantage/
> > (Note: If this link does not work for you the first time you try it, go
> > to
> > www.egroups.com, login and be sure to save your password, choose My
> > Groups,
> > choose Vantage, then choose Files. If you save the password, the link
> > above
> > will work the next time you try it.)
> > to www.egroups.com, login and be sure to save your password, choose My
> > Groups, choose Vantage, then choose Files. If you save the password,
> the
> > link above will work the next time you try it.)
> to
> Groups,
> above
> Groups, choose Vantage, then choose Files. If you save the password, the
