Hello,
I am using the send email widgit.
I have a date field in the body of the message and it sends the date and time.
Is there an easy way to format it to show only date?
Hello,
YourDateVariable.ToString("MM/dd/yyyy")I tried that and got
Ah, my apologies. Forgot the nullable date time was different.
AdjDate.Value.ToString("MM/dd/yyyy")
Edit: If you are worried that the date will ever be null, use this instead:
AdjDate == null? "[N/A]": AdjDate.Value.ToString("MM/dd/yyyy")
How in the world did you know it was nullable?
In Epicor Functions, the only Date type request parameter is the nullable (DateTime? rather than DateTime). So literally every time I make a function with a Date input, I get that same error because I forget about the nullable ![]()
