Karen,
Â
I went ahead and added a check box and combo box to the Demand Header Screen. I had no problems doing this and they seem to work. I also just added this change to the Manager not everyone.
Â
Let me test some more and see if maybe something is not working properly.
Â
Jonathan LangÂ
Oil Rite Corporation
Sr. Network Administrator
Ph: (920) 682-6173 Ext: 126
Fax: (920) 682-7699
Â
Â
Â
Jonathan LangÂ
Fax: (920) 682-7699
--- On Fri, 4/3/09, Karen Schoenung <kschoenung@...> wrote:
Subject: RE: [Vantage] cannot enable custom field
Date: Friday, April 3, 2009, 10:05 AM
Jonathan,
Yes, I am in developer mode. I have security manager security (In
TEST), with customization ability (I have setup other fields). I am
working in the Demand Header screen which seems to have all fields
disabled...I want to update the field by unchecking if possible. We are
on 8.03.407a.
Karen
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Jonathan Lang
Sent: Friday, April 03, 2009 9:54 AM
To: vantage@yahoogroups .com
Subject: Re: [Vantage] cannot enable custom field
Karen,
Are you doing this in Developer mode on an App? If so what are the
security settings? What user are you doing this for or are you creating
a general use change?
Jonathan Lang
Fax: (920) 682-7699
--- On Fri, 4/3/09, karen_schoenung <kschoenung@fisher- barton.com
<mailto:kschoenung% 40fisher- barton.com> > wrote:
From: karen_schoenung <kschoenung@fisher- barton.com
Subject: [Vantage] cannot enable custom field
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
Date: Friday, April 3, 2009, 9:39 AM
Hi,
I have a custom checkbox that I cannot enable...I have also tried to
enable the same item, but in a textbox...I am working in the Demand
Entry screen, Header tab - even though the text box shows enabled and
read only as false, I cannot type here. The check box has no read only
option, but enabled is true...I cannot check or uncheck the box.
Any ideas?
Karen
