Cannot use Resource table in SQL Select
Bad URL.
Here's the right page in the PDF for Progress Reserved Words:
http://bit.ly/140fBC9
Vic Drecchio
Sent: Wednesday, July 31, 2013 4:29 PM
Subject: RE: [Vantage] Re: Cannot use Resource table in SQL Select
Ahh, makes sense. It was very smart of the developers to use reserved words
for table and field names. /sarcasm
Here's a complete list of Reserved Words in Progress if anyone is curious:
http://bit.ly/17UmN32
Behalf Of
sosnowbored
Sent: Wednesday, July 31, 2013 4:20 PM
Subject: [Vantage] Re: Cannot use Resource table in SQL Select
Unfortunately Resource is a reserved keyword in the Progress SQL server. To
access it you will need to escape it with double quotes like:
SELECT * FROM MFGSYS.PUB."Resource"
Also be aware that your permission scripts may have bombed when granting
ODBC users permission to that table. I could access it with sysprogress but
not my standard ODBC login until I wrapped the table name with double quotes
on my permission granting script.
Aragon
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com> ,
"mmcwilliams22" <mmcwilliams22@...> wrote:
> Have a simple select statement where I can use about any other table but
as soon as I have SELECT Resource.ResourceID or any other Field from that
table I get an error. Is resourceID a property of something possibly and it
is trying to interpret it as such?
Have a simple select statement where I can use about any other table but as soon as I have SELECT Resource.ResourceID or any other Field from that table I get an error. Is resourceID a property of something possibly and it is trying to interpret it as such?
What's the error? I've selected from that table many times...
mmcwilliams22
Sent: Wednesday, July 31, 2013 1:27 PM
Subject: [Vantage] Cannot use Resource table in SQL Select
Syntax error in SQL statement at or about "Resource.ResourceID From Mfgsys.Pub.Reso"(10713).
For testing I am just trying to get it to not error out using
sql = "SELECT Resource.ResourceID FROM Mfgsys.Pub.Resource"
I can plug in other tables and it does not error out.
> mmcwilliams22
Try aliasing, sometimes SQL is a little B
SELECT A.ResourceID FROM Mfgsys.Pub.Resource A
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
> Behalf Of
> > mmcwilliams22
> as
> table
Does not like that either. It moved the syntax error down towards the end though. It now is at or about "Resource A"(10713). I can alias it with other tables no problem also.
This is in a form customization mind you.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Behalf Of
> > > mmcwilliams22
> > as
> > table
You are writing SQL in a customization? VERY VERY FROWN FACE, if you are
trying to populate a combobox or whatnot use the BOs or Retreivers..
Some others here (I am looking at you Vic) will tell you its Ok to run SQL
straight like that, but its very frowned upon by Epicor and truth be told
the Architecture is such (SOA) that you should be able to get any piece of
data without going to the DB directly
Now is your DB going to blow up? No probably not, but if something does
happen and you need support they can use that as a crutch to not support
you..
With that all said, I don't know what the problem is, looks odd.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > Behalf Of
> > > > mmcwilliams22
> but
> > > as
> that
> > > table
> it is
Yes I am using a UD table to create a grid of a custom dataview(ReadOnly). Im pulling different fields from JobHead, Customer,JobOper,JobOpDtl,JobProd and then displaying in the custom grid view. They can edit UD fields only in the grid, however, the Adapter is used to update the actual tables.
> you..
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > > > Behalf Of
> > > > > mmcwilliams22
> > but
> > > > as
> > that
> > > > table
> > it is
ok its strainge, have you tried running the same query in SQL Studio or SQL
Squierl'?
*Jose C Gomez*
*Software Engineer*
E: jose@...
> SQL
> of
> > you..
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> end
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> On
> > > > > Behalf Of
> > > > > > mmcwilliams22
> table
> > > but
> > > > > as
> > > that
> > > > > table
> and
> > > it is
Hahaha... I'm not on E9 yet, so I don't even have this ability, Mr. Jose.
I didn't realize you were trying to run it within a customization...
therefore, yes, perhaps "resource" is not a nice column name within
customization.
My final suggestion would be to enclose the SQL statement in brackets:
SELECT [ResourceID] FROM [Mfgsys].[Pub].[Resource]
Jose Gomez
Sent: Wednesday, July 31, 2013 2:23 PM
To: Vantage
Subject: Re: [Vantage] Re: Cannot use Resource table in SQL Select
you..
*Jose C Gomez*
*Software Engineer*
E: jose@...
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > For testing I am just trying to get it to not error out using sql
> > > > On
> > > Behalf Of
> > > > mmcwilliams22
> > > > table
> but
> > > as
> > > > from
> that
> > > table
> > > > and
> it is
Unfortunately Resource is a reserved keyword in the Progress SQL server. To access it you will need to escape it with double quotes like:
Also be aware that your permission scripts may have bombed when granting ODBC users permission to that table. I could access it with sysprogress but not my standard ODBC login until I wrapped the table name with double quotes on my permission granting script.
Aragon
sosnowbored
Aragon
