Thank You. If you ever get to the bottom of why Vantage locks up after inactivity please share the fix with me.
I will do the same.
Thanks again.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Chris Thompson
Sent: Thursday, March 03, 2011 8:02 AM
Subject: Re: [Vantage] Cant close Vantage. Session Manager window popping up.
If you exit the System Monitor then try closing Epicor it should close.
As to why its locking after inactivity - this is an issue I am also getting and
cant seem to get to the bottom of.
From: vacortes21 <vcortes@... <mailto:vcortes%40triumphgroup.com> >
Sent: Thu, 3 March, 2011 15:37:12
Subject: [Vantage] Cant close Vantage. Session Manager window popping up.
Hi, in Vantage 8.03.409C some users get a "Vantage Session Manager" window when
they try shutdown Vantage. the only way we are able to shut the Vantage session
down is to kill the process through Task Manager. This usually happens when a
user leaves Vantage running without using it for a long period of time. Then
when they want to use it you can see the Vantage Window but can't click on
anything and then when you try to Shut it down the "Vantage Session Manager"
window keeps popping up. Please Help! Thanks in Advance.
This message has been processed via your triumphgroup.com e-mail address.
______________________________________________________________________
This email has been scanned by the MessageLabs Email Security System.
For more information please visit http://www.messagelabs.com/email
I will do the same.
Thanks again.
