Hi!
We’re in epicor implementation phase, I’m making reports we’ll be using.
All I want to add is bank account information from BankAcct table joined to customer, which is joined to orderhed.
The bank account info is chosen from the customer ‘preferredbank’. I can’t however see any mention of the bank part, anything I’ve added at all really, in any of the datasets in report builder.
I have trailed through whatever I can online including epiusers, but cant find why I am unable to call from BankAct
I have no exclusions in bankacct table, mainly because it previously wouldn’t give me any proper table joins previously.
What I’m missing must be standard but is surely RDD related else it wouldn’t be regenerative right? I can’t get it to work following any previous threads
A few things come to mind that you can review and verify…
First, when I add relationships, and I want to USE data from the added table, I will set the Relationship Type to “Output”, not “Definition Only”.
Secondly, you’ve added the tables to your RDD. But in the RDD, did you go into the Report Table / Detail and un-exclude the columns you want to use in your report? They will all be excluded by default.
Edit: Sorry you already verified that portion:
Thirdly, just adding the table to the RDD is not going to make the fields magically appear in your Report Builder RDL file. You have to manually add them to your dataset query AND add them as query fields.
I see;
I haven’t found a proper definition between output and definition only and documentation seems out of date.
I had in my head that since it generates the document/dataset on first usage of a report style, it would be regenerating it all and whatever changes must be before that in RDD.
I suppose if the dataset is created but is saved as the report file on the DB it could be changed and persist. I’ll hope this is the only thing that I needed, thanks
