Carrier table column issue?
i am writing custom code in method directive, and trying to access the Carrier table. seems like the carrier table primary key “Carrier” is clashing with table name “Carrier”.
any workarounds? @Bart_Elia
var ttCarrier = (from cr in Db.Carrier where cr.Company == Session.CompanyID && cr.Carrier ==101 select cr).FirstOrDefault();
Error:
does not contain a definition for 'Carrier and no extension method ‘Carrier’
Use Carrier1 as the field
thank you @jose for your prompt responses. it worked.
Yup use the 1.
That’s entity framework behavior on name conflicts over table and column
