CDC Log Processor
Does anyone have any advice on how to set up the CDC Log Processor? In the Help, it says 30 minutes for the Run Time and to select a schedule that runs every hour. Not sure if that is good or not. :man_shrugging:
So what matters is how sensitive you are to ‘down time’. The CDC processor failing to run for x hours is either OK or a disaster. So our advice is to keep it running. the best way to do that is with an interval schedule and set the interval to how long you are OK with it being down. Just makes sure you set it to run for <= the interval or you will get a lot of ‘already running error’ in your system monitor.
Thanks @pferrington , I appreciate the response.
Sorry to respond to an old thread.
I was wondering what the difference is between choosing the “Auto resubmit” option and choosing a schedule with the option of “Recurring” on?
