Hi!
We are trying to set up a new VPN.
Our Prod server has a web based SSL, apparently for security in case we ever expose Epicor to the web, but it’s causing issues for us now. It won’t connect when the VPN is running.
Our Dev server, which is on local and uses personal certificates, however DOES work when the VPN is running.
Do we need to have an SSL if we’re not exposing Epicor to the web? Can we have a personal/local certificate instead?
Thank you.
