I'm currently trying to do this by exporting a report of part numbers
which now use average costing (for instance) and then using Macro
Express to run through these parts and change the costing method to
standard. I'm not entirely sure it's going to be a robust solution but
at least it's only needed once!
Nigel Roberts
MC Sheet Metal
Wales, UK
Date: Wed, 10 Jan 2001 14:10:55 -0000
Subject: Changing Costing Methods
We're running Vantage 4.0, and currently have our purchased parts set
up using Average costing and everything else is set to Standard
costing. We want to change to using Standard for everything. I'm
told that to accomplish this, we'll need to go into each part
individually that we want to change, and zero out the quantities,
change the costing method, and then add the quantity back in. Does
anyone know of an easier way to do this?
Thanks!
Denise Brown
Nigel Roberts
MC Sheet Metal
Wales, UK
Thanks!
Denise Brown
