Thanks that would be great! I have never done a customization before so
please do assume anything. How about the Parts description field on the
part entry form.
Thanks for all of your help!
Dale Kalsow | Information Technologies Director | Determan Brownie,
Inc.
Work: 763-502-9689 | Fax: 763-571-1789 | Mail:
dale.r.kalsow@... <mailto:dale.r.kalsow@...>
"Ambition is the path to success. Persistence is the vehicle you arrive
in."
Electronic Privacy Notice. This e-mail, and any attachments, contains
information that is, or may be, covered by the Electronic Communications
Privacy Act, 18 U.S.C. 2510-2521, and is also confidential and
proprietary in nature. If you are not the intended recipient, please be
advised that you are legally prohibited from retaining, using, copying,
distributing, or otherwise disclosing this information in any manner.
Instead, please reply to the sender that you have received this
communication in error, and then immediately delete it. Thank you in
advance for your cooperation.
Of bw2868bond
Sent: Thursday, September 04, 2008 1:14 PM
Subject: [Vantage] Re: Change Case
I would do a screen Customization (BPM not available 8.00.812)
In the layout event of the control set the CharacterCasing property
to CharacterCasing.Upper
If these are custom fields added to your form, the event wizard can
create the event handler for you. If they are base form controls, you
will need to add a bit more code. If you had a form and control in
mind I could give a sample.
Bernie.
"Dale R. Kalsow" <dale.r.kalsow@...>
part entry form.
Inc.
in."
Of bw2868bond
Bernie.
wrote:
>way to
> If we want specific fields to always be in upper case is there a
> do this? Can it be done with a screen modification and or a BPM?[Non-text portions of this message have been removed]
> Thanks!
> Dale
