Thank you for the BPM. I haven’t tried importing yet (not sure where to actually). I am trying to figure out how to ues the action. Any chance you could look at this and not where I’ve gone wrong?
“set the ttPart.UpdatePartPlant field of all rows identified by the ttPart query to the true expression”
For the ttPart query I have: for first ttPart no-lock where ttPart.RowMod = 'U’
When I compare the log between my BPM and without, I see that without will fire the ChangePartPlantSourceType method. Do I need to add this somehow in my BPM?
The BPM doesn’t fire anything it just fires along with whatever is triggered in the UI.
What does the trace say as far as params in and out during the actions you described in your original post.
What you are trying to do might not even be possible. Sometimes there are flags in the methods that you can set to bypass message like that, sometimes you will have to write custom code, sometimes you are straight up SOL and it’s not worth the time and materials.
To test, I change the costing method on a part from Avg to Std.
Using non-BPM way:
When clicking save I get “You have changed the following fields: Cost Method. Do you want to refresh the part plant records with the changes?”… I click “Yes”.
Action #10: Part.CheckPartChanges - The params are CostMethod=S, UpdatePartPlant=F, and DBRowIdent.
Action #17: Part.ChangePartPlantSourceType - The params are CostMethod=S and DBRowIdent.
Action #22: Part.Update - The params are CostMethod=S, RowMod=U, and DBRowIdent.
Using the BPM you provided (along with adding set cPartChangedMsgText = “”):
Action #10: Part.CheckPartChanges - The params are CostMethod=S, and DBRowIdent
Action #15: Part.Update - The params are CostMethod=S and DBRowIdent
I tried that (just double-tried) and the same actions/params exist:
(when set to false)
