Change default printer option?
Version 10.2.600.9
When we click on the printer Icon, it always brings up the ‘Client Printer’ option first, can you change this to show the ‘Server Printer’ option first instead? Please see attached screenshots.
Thank you for any help or feedback as always.
In the Company maintenance you can set one or the other. I’m not sure if it is possible to change which should display first.
Yea I knew about that but that doesn’t impact the order in which they are displayed. Thanks for the reply though, it’s appreciated.
Can you test creating a workstation, add the devices(printers to the workstation) and then add the workstation to the user. See if that fixes the issue.
