Change PO line unit cost using the POAdpater
Hi All (E10.2.600)
I have a UI customization on Customer Shipment Entry that will create a purchase order based on certain conditions.
Everything was working but I was not anticipating that some of the part numbers involved would have a supplier price list and for these specific POs, that the customization is creating, the unit cost needs to be zero.
I did as UI trace and a BO trace to find how how to set the price to zero but it is not working.
The code snippet I have is:
poAdapter.POData.PODetail[lineCount].RowMod = “U”;
poAdapter.POData.PODetail[lineCount].DocScrUnitCost = 0;
poAdapter.ChangeUnitPriceConfirmOverride(out sConfirmMsg);
poAdapter.ChangeUnitPrice();
poAdapter.Update();
I’ve tried running this after creating a new PO line but before saving the PO line and I’ve tried moving it ti after the PO line is saved.
In both cases, the price does not change.
I am also updating the PO line Override Price List checkbox, which is getting updated.
Any ideas on what I am missing to change the PO line unit cost?
A couple of things: If you’re setting line qty’s, set those first and then the unit prices. I saw something similar but for the SOs and, if I remember correctly, it requires both fields set to 0 (doc and company currency). Try setting the other as well - a long shot but it may work.
poAdapter.POData.PODetail[lineCount].ScrUnitCost = 0;
Thanks Dragos!
I tried setting both versions of the unit cost fields as you mentioned and that seems to have done the trick.
