Change print previews PDF default names (ERP 10/11 may work as well)
Hello everyone,
I am trying to change the default file name for all report preview PDF files. I checked a few report-related menus, but they don’t have anything related to this. I tried to find similar issues and couldn’t find anything either.
Currently, Epicor’s process is grabbing the most recent unique identifier and adding +1 to it. For example, when you print preview of SalesOrderAck #14000, it will also name the next invoice to ARInvoiceForm_14001.pdf unless the invoice number is higher than the SalesOrderAck number.
Here’s an example of what I’m trying to accomplish:
I am trying to get a PDF of AR Invoice #13000. However, I don’t want the file to be named ‘ARInvoiceForm_14001.pdf’, following the most recent SalesOrderAck number. Instead, I want to name it to the actual invoice number which is something like ‘ARInvoiceForm_13001-2023_08_07.pdf’. I can use the date and “HHMMss” as a unique identifier so that I don’t run into duplicate report names should that be an issue.
Any help would be appreciated.
Thank you!
Did you happen to find a solution for this? I am in the same boat as you.
Thanks.
Don’t think it works in the edge agent. Been a minute.
This should be an idea/
I’ll at it to the Fr!deas.
Allow Custom SSRS PDF Name Generation | Epicor Kinetic Ideas Portal (aha.io)
@fakhruddin already beat me to it and created the exact same idea!
Generated Reports with dynamic PDF file | Epicor Kinetic Ideas Portal (aha.io)
Thanks everyone for posting this as an idea.
Unfortunately, I have not been able to find a solution for this yet @kepler7b
Thank you Kevin!
Manuel, did you check Kevin’s BPM code? For now, I believe that would be a good solution.
Appreciated, I must have missed this one. Looks like it can be helpful. I’ll have to give it a try since I’m on Kinetic.
nice one :slight_smile:
Kevin is very nice.
Why thank you..
proud oh yeah GIF by Sky
Don’t be fooled though..
the screaming skull GIF
