Correct. You won't loose your relationships of previous transactions, but it
is confusing because there is no reference to the old number. If you print
out the invoice, only display the new information, even if it has been
posted.
Daniel
_____
markewhittaker
Sent: Friday, August 15, 2008 4:23 PM
Subject: [Vantage] Re: Change Supplier ID
Changing the supplier id will NOT cause you to lose the relationship
to previous transactions. Vantage has a vendornum field on the
vendor table that is system-generated and never changes. It uses
this field to relate the vendor record to related transactions.
Changing the supplier id changes the vendorid field, not the
vendornum field.
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Daniel
Laidig" <daniellaidig@...>
wrote:
Behalf Of
posted.
Daniel
_____
markewhittaker
vendornum field.
wrote:
>the ID.
> It won't let you merge two existing suppliers. You can only change
> Also, it will affect all of your previous transactions. Forinstance, any
> sales order, shipping pack, or invoice will now not have anyreference to
> the old number. So if you look back on an old invoice, it will lookthe current
> different. This is kind of a pain. I wish the invoice captured
> customer's information like name and address, because if that stuffever
> gets changed, you don't know what the original invoice looked likeunless
> you print out and file a hard copy at the time of invoice.[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
> Daniel
> _____
> From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Behalf Of
> Michelle C. Grmanwatch
> Sent: Thursday, August 14, 2008 3:42 PM
> To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> Subject: [Vantage] Change Supplier ID
> I am investigating the use of the Change Supplier ID to merge two
> suppliers. We are on Vantage 8.03.404A. Does anyone know of any
> outs I should be concerned about with the supplier change ID[Non-text portions of this message have been removed]
> functionality?
> Michelle C. Grman
> Assistant Controller
> KERUSSO
> The Greek word means - To herald divine truth as a public crier; to
> preach the gospel.
> P.O. Box 32
> Berryville, AR 72616
> Phone: 870-423-6242 Ext. 267
> Fax: 870-423-3568
> Web Site: www.kerusso.com
> "A well-stocked display is a well-shopped display."
> Let us help you optimize your Kerusso inventory levels--and MAXIMIZE
> your sales!
> CONFIDENTIALITY STATEMENT:
> This message, from Kerusso Inc., contains information
> which is privileged and confidential and is solely for the use of
> the intended recipient. If you are not the intended recipient, be
> aware that any review, disclosure, copying, distribution, or use
> of the contents of this message is strictly prohibited. If you have
> received this in error, please destroy it and notify us immediately
> at: 800-424-0943
