I’ve just noticed that a trick I’ve used in dashboards no longer works.
When I want to be able to filter the data based on a boolean field, but sometimes want to ignore it, I’d create a calc field (char) in the BAQ, that would be ‘YB’ when the bool was true, and ‘NB’ when it was not. Then I could add a prompt in the dashboard’s tracker with condition “Matches”.
Entering a Y in that field resulted in records where the bool was TRUE
Entering a N resulted in records where the bool was FALSE
Entering a B (or leaving it blank) resulted in records where the bool was TRUE or FALSE
But now (after upgrading from 10.1.400 to 10.2.300), this no longer works. I’m now required to enter a Y* or N*.
It’s an easy enough fix (change the calc to just Y or N, and use a blank entry for either).
But the fact is, this looks like a significant change. Anyone else notice this?
