Thanks..
I tried it and it worked..
Marty
Marty
>like this
> The estimate comes from the part cost and its cost method. Sounds
> maybe incorrect? That should be adjusted accordingly too,however, in job
> entry you can update the unit cost of each material line.Behalf Of
> _____
> MartyMaterial
> Sent: Tuesday, February 17, 2009 4:25 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Changing Estimates on Production Detail Report
> Is there any way of changing the Estimate Side of the Production
> Detail Report after a job has been set up.
> I came across a situation where the Estimated Cost of a Raw
> is wrong and wanted to know if there is any way of changing this
> information on this Job.
> The Actual Side is correct just not the estimated side.
> I looked in Job Adjustment and couldn't find anything in there.
> thanks.
